Announcement
Collapse
No announcement yet.
C300 mkiii SDI / HDMI issue
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
    C300: C300 mkiii SDI / HDMI issue
    Hi,
    When shooting 4K C300mkiii doesn't let the SDI MON out and the HDMI work at the same time. The SDI out and HDMI work at the same time BUT the SDI doesn't downconvert the 4K signal (MON out does down convert to HD) so if I'm using a Zacuto viewfinder and a Teradek ACE at the same time, I'm screwed. The viewfinder won't take 4K signal and I obviously can't use SDI Mon out and HDMI out at the same time. This was never a problem on the C300 MKii.
    Does anyone have a good work around?!
    Thanks.
    #2
    If they don't eventually fix this known problem, you'll have to loop out of hardware that can accept 4K but only output HD (like a 5" HD Video Assist) or more advanced options which may provide you signal settings.
    With any options you find it's best to research what kind of delay there may or may not be with your particular set up.
    Comment
      #3
      Originally posted by tonta9 View Post
      Hi,
      Thanks.
      These UpDownCross won't handle your 4K but if you need extra SDI and HDMI at the same time you can use these. Good little Swiss army knife. If you don't need to 'convert' a signal you can just use them as an SDI/HDMI distributor if you set switch #1 to OFF. I power mine from D Tap.
      Chris Young
      https://www.blackmagicdesign.com/au/...miniconverters
      Comment
        #4
        Chris Young
        This might be a decent workaround for now… where do you get the d tap power adapter? Thanks!!!
        Comment
          #5
          I'm running V Loc batteries along with a 4 port V Loc distributor so no problems there. If you require just one extra SDI out you could use one of these maybe. It's a 1 x 2 passive splitter from Apantac. These require no additional powering and are good for about 30-yard cable runs. Which obviously shouldn't be much of an issue if you are mounting this on your camera somewhere. I've used a similar unit attaching it to the camera with Velcro.
          Chris Young
          https://www.markertek.com/product/ap...tion-amplifier
          Comment
            #6
            Chris Young
            Oh I meant where do you get the d tap power cord to that BM box? I have plenty d tap outputs from battery plate.
            Comment
              #7
              Sorry misunderstood. I buy mine from my regular professional video store. There are many variations on eBay of the correct spec cables such as this one with a 5.5mm x 2.5mm power plug.
              Chris Young
              https://www.ebay.com.au/itm/32413609...8AAOSwsG9eldBg
              or this from BH Photo. They have various length ones, coiled and straight.
              https://www.bhphotovideo.com/c/produ...cable_for.html
              Comment
                #8
                I'm running into the same problem every time I have to set a remote interview or a simple wire to village. It's very frustrating! So far I have been looping through my monitor (SmallHD 702) but it's adding a fair amount of latency... @cyvideo does the BM Mini Converter add any latency?
                Comment
                  #9
                  To the best of my knowledge on the info I have from BM is that if you have dip switch #1 in the ON position as you would if doing a "conversion" from one standard to another there is a 1 frame delay due to the conversion processing regardless of what frame size or the number of FPS you select for your output conversion. If you are running UpDownCross with dip #1 in the off position you are basically using it as a video distributor and no processing is going on. The output format will be the same as the input so the SDI is straight through with no delay. Also, remember there is an SDI "loop through" port. So even if you are doing a process on conversion through to the output ports the loop through will not be affected by that one frame processing delay. If you are using the HDMI output and are inputting SDI without any format conversion then there is apparently a 1 line insertion delay. Which is really of no significance in the real world of production. As I say this is to the best of my knowledge and so far my experience is bearing that out.
                  Chris Young
                  Comment
                    #10
                    Canon just announced an FW update to clear up this issue in both the C500M2 & the C300M3:
                    https://youtu.be/huyRvn_P8TE
                    Site | Blog
                    Comment
                      #11
                      That should make some Canon owners very happy.
                      Comment
                        #12
                        Thanks Jon, good to know.
                        Seeing some of the builds in the video reminded me of the canon expansion units. I almost forgot they were an accessory - most people seem happy without them.
                        robnortondp.com
                        Comment
                          #13
                          This is a great update, stoked!
                          👉 My Filmmaking YouTube Channel
                          Comment
                          Working...
                          X
