Results 1 to 4 of 4
  1. Collapse Details
    SPEED Edit in 4K and 50% downsize on a 2K timeline VS edit natively in 4K
    #1
    Default
    Sorry if this has been asked before.
    Would it be faster, slower or equal in Premiere to
    A) edit 4K material and 50% downsize on a 2K timeline sequence
    VS
    B) edit 4K material on a 4K timeline
    specifically I'm talking about mainly Canon MXF 422 footage out of C300m2, and a project w hundreds of hours of material and a 2 hour + timeline
    Would it make any difference if you also include upscaling some 2K material to 4K?
    Thanking You In Advance!
    Best
    /V
  2. Collapse Details
    #2
    Senior Member
    Join Date
    Feb 2009
    Location
    Long Island
    Posts
    9,800
    Default
    No difference in terms of raw performance as the source is still 4K, whether it's in a 4K timeline or a 2K timeline.
    However, playback - depending on how you playback footage/its quality - may (or may not) improve if doing it in a lower-resolution timeline.
    Per usual, best way to answer this question is to test footage you'd be personally working with in your own personal system/software.
    1 out of 1 members found this post helpful.
  3. Collapse Details
    #3
    Default
    Thanks for your reply.
    Im mid-project thinking of switching to 4K timeline for a possible 4K online-master (broadcast-master is only 2K). Im thinking graphics would be better too etc but dont want to slow down the editing process. If its a minor difference then I think I will junp ship and take the 4K sequence train.
    Havent seen much difference so far when trying, but havent tried a massive project / sequence.
  4. Collapse Details
    #4
    Senior Member
    Join Date
    Feb 2009
    Location
    Long Island
    Posts
    9,800
    Default
    Everything will look better if a lot of it is of a higher-resolution...because currently the extra pixels are being thrown away in the 2K timeline.
    I always edit in a native timeline and then export lower-resolution masters from that.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
