Page 4 of 4 FirstFirst 1234
Results 31 to 34 of 34
  1. Collapse Details
    #31
    Default
    Please let me know where it is explained how to control the exposure on the HV20 using the mini SD card---prefer to do it the easy way!! Not clear from the posted article what steps one takes for the mini SD card method. Thanks!
  2. Collapse Details
    #32
    Default
    When you have the mini-SD card installed, then when you push down the "photo" button halfway, the display will show what f-stop you're at. So you control exposure normally, with the EXP slider, but you can at least spot-check and see what f-stop the system is selecting.
  3. Collapse Details
    #33
    Default
    check out this guys work with the hv20 maybe he can answer a couple of questions people seem to have trouble with
    www.youtube.com/k3films
    he shoots all in hv20 with 35mm adapter
  4. Collapse Details
    #34
    Junior Member healthinsider's Avatar
    Join Date
    Feb 2010
    Location
    Michigan
    Posts
    1
    Default
    Quote Originally Posted by DavidD View Post
    Ok, I finally put up a video showing a walk-through of using the Lytecap (where I found time to do this, is still a mystery to me).
    http://www.lytecap.com/multimedia.htm
    Thanks for the guide.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
