I am using a mac powerbook G4 , quicktime pro 7.1.3 and I cannot play
QT movies with the following codec:
DVCPRO HD(720p60)
timecode
Any links or suggestions?
Thread: codec question for QT pro
Results 1 to 9 of 9
Junior Member
- Join Date
- Jul 2006
- Posts
- 10
12-02-2006 05:40 PM
Senior Member
- Join Date
- May 2004
- Location
- Teaneck, NJ
- Posts
- 2,288
12-02-2006 05:47 PM
Should have been installed with your Final Cut Pro installation.
Ned Soltz
Senior Member
- Join Date
- May 2004
- Location
- Teaneck, NJ
- Posts
- 2,288
12-02-2006 07:29 PM
The DVCPRO HD codec is installed with FCP. That's kind of what I thought when you indicated that you could not play back the material. So, in order for QT Pro to play it back, you must have installed FCP which will in turn install the codec in your QT components folder.
Ned
Junior Member
- Join Date
- Jul 2006
- Posts
- 10
12-03-2006 09:43 AM
Thanks Ned,
How about a different question then...
The director would like to view footage on his computer (older mac lap top without final cut HD). What do I need to do to get him viewable quicktime files?
Thanks again,
Jennifer.
Senior Member
- Join Date
- Apr 2006
- Posts
- 146
12-03-2006 03:46 PM
Jennifer, the underlying problem is that you must have the DVCProHD codec on the director's computer. Apple has chosen to distribute these as part of the pro-apps (FCP) installation, not as QT resources (which for my 2 cents would make more sense).
Originally Posted by pvfilm
So, for anyone to play HD-QT files they must have the codec on their computer. Imagine offers a .dmg installer to assist in copying just the codecs from a FCP 5 installer CD.
Another alternative I suppose is to change the format of the QT file to something that doesn't require the HD codec (eg. DV, H264, etc, etc). Only the DVCProHD codecs are the ones *not* included in generic QT installations.
Hope this helps.
Senior Member
- Join Date
- May 2004
- Location
- Teaneck, NJ
- Posts
- 2,288
12-03-2006 05:40 PM
Jennifer
Dan beat me to the punch on the answer!
Ned
- Join Date
- Dec 2006
- Location
- Montreal, QC
- Posts
- 34
12-03-2006 06:40 PM
I am unsure if this works, but I have been researching this myself, trying to get a g3 laptop to play dvcpro hd material just for viewing. It can't because I believe Alti-Vec is tied to this compression (so you need G4 or better). BUT I did find this, and since I don't have a g4 or higher computer that I can test this on that doesn't have Final Cut, maybe someone else will.
http://www.apple.com/support/downloa...omponents.html
It says install FCP, but don't do it and see. This seems to me to be the Quicktime components for DVCPRO HD, but perhaps not. Someone check it out.
12-04-2006 07:35 PM
Why not just upgrade? Seriously!
"When my HVX grows up it wants to be a VariCam."
Junior Member
- Join Date
- Oct 2005
- Posts
- 18
12-05-2006 09:26 AM
Copy the DVCPROHD Codecs from /Library/QuickTime to the same folder on your other machine, then restart it.
-b
