Page 12 of 19 FirstFirst ... 28910111213141516 ... LastLast
Results 111 to 120 of 187
  1. Collapse Details
    Senior Member macgregor's Avatar
    Join Date
    Jan 2005
    Location
    in the Canary Islands
    Posts
    1,795
    Default
    Question: if 4.5K Redcode RAw cannot be recorded onboard, but 4K Redcode RAW can be, it seems to me that the problem comes from the compressing processor, it is not a writing/speed problem. Otherwise it would be as easy as compressing a bit more the footage so you get the same data rate as at 4K.
    But again, if it is a speed processing issue, and 4K 30fps is possible, wouldnīt be possible 24fps at 4.5K?
    www.macgregor.autoecstasy.com
    Macgregor™ is a trademark of Miguel de Olaso
  2. Collapse Details
    Senior Member Muttondraw's Avatar
    Join Date
    Sep 2006
    Location
    Surrey. UK.
    Posts
    226
    Default
    For me the biggest issue is the reduced FOV going to a smaller format size, but I guess that is fixable, just means wider (more expensive) lenses. I had bought in to the S35 format option, it just hadn't dawned on me that it wouldn't be that viable in some permutation or other. Underlines how relevant your table is Haakon.
    I think an important aspect to hold on to is that 2K is still in excess of what we are seeing in most theatres today.
    Martin
  3. Collapse Details
    Senior Member
    Join Date
    May 2004
    Location
    Connecticut
    Posts
    352
    Default
    Quote Originally Posted by Muttondraw
    Martin
    very true
    My most used on-set statement? "That seems unnecessarily dangerous."
    www.adriancorreia.com
    RED #321
    RED Zoom #85
  4. Collapse Details
    Join Date
    Sep 2006
    Location
    Surrey. UK.
    Posts
    226
    Default
    Quote Originally Posted by macgregor
    Or as Stephen W suggested in a previous thread. http://www.dvxuser.com/V6/showthread...t=redcode+4.5k If we could shoot windowed in a 2.40:1 ratio (rather than 1.77:1) but using the full sensor width. So you would only use 4520x1890 pixels. That would bring the data rate down.
    Martin
  5. Collapse Details
    Join Date
    Jan 2005
    Location
    Posts
    1,795
    Default
    Martin
    Wonderfull idea.
    Note: isnīt real scope aspect ratio 1:2.39?
  6. Collapse Details
    Senior Member laboprod's Avatar
    Join Date
    Jun 2005
    Location
    Switzerland
    Posts
    109
    Default
    Thanks Martin for your confirmation on my FOV question.
    4k RAW REDCODE onboard is great, and I do not think there is something to be disapointed of. I mean there is no such difference between 35mm and S35mm.
    If 4,5k RAW REDCODE is going to be available onboard it would even be better, but as macgregor has very well resumed it, not sure what is the problem...
    About the lens, I have planed to use the REDZoom, and switching between the 4k and 2k windowed, I will have a FOV from around 7 degree to 60 degree, on the same camera, which is kind of cool...
  7. Collapse Details
    Join Date
    Jan 2005
    Location
    Posts
    1,795
    Default
    The difference between S35 and 35 might be small, but it exists.
    Basically because you get wider lenses at the same mm and you can get less DOF.
  8. Collapse Details
    Join Date
    Sep 2006
    Location
    Surrey. UK.
    Posts
    226
    Default
    Wonderfull idea.
    Yes but it is commonly referred to as 2.40:1. I think that is what the ASC calls it.
    Martin
  9. Collapse Details
    Default
    Wonderfull idea.
    Miguel, I think you're right but it would be interesting any other confirmation(s). This will be a sensitive aspect to take care.
    EDIT -- And if the ASC doesn't handle with the pixels by tradition, the digital cinematographer will work with the accurate number and not by estimate approach, genre 1:2.40.
    RED ONE @home
    #111
    Emanuel & Co's RED ONE
    #647
    RED ZOOM LENSES
    #156
    #157
    RED 300mm LENS
    #82
    Who am I?
    LINK
  10. Collapse Details
    Join Date
    Sep 2006
    Location
    Surrey. UK.
    Posts
    226
    Default
    Martin
    Ah ha. Found this older thread discussing the same possibility. This time with a contribution from Graeme. http://www.dvxuser.com/V6/showthread.php?t=58165 Although they were only talking about windowing the height of a 4K image.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
