Thread: DIY Butterfly
Page 5 of 5 FirstFirst 12345
Results 41 to 44 of 44
  1. Collapse Details
    #41
    Senior Member
    Join Date
    Nov 2008
    Location
    Nashville
    Posts
    255
    Default
    found a few bags of parts from canopies that i think are going to work great for this. Need to get some angle tubing to make it square. Should be light enough to hang above head. Now in need of material.
  2. Collapse Details
    #42
    Junior Member
    Join Date
    Sep 2010
    Location
    Jodhpur, Rajasthan, India
    Posts
    14
    Default
    I just whatched your film invitation... REAL TOUCHING ONE!!! Cann't stop myself to reply a long ago thread comment... Really Nice...
    Quote Originally Posted by Larry Rutledge View Post
    I got these plans off the internet a while ago (my apologies to the original author, I don't remember where I got it). I built a couple of them and used them for my film INVITATION, they worked very well.
    Here's a link to a PDF of the plans: http://www.day7studios.com/nrestudio...n_diffuser.pdf
    Hope that helps,
    Larry
  3. Collapse Details
    1" Aluminum Square Tube Resources
    #43
    Default
    In case you did want to make it out of square tube, instead of PVC or conduit...
    http://www.amazon.com/Steelworks-Bol.../dp/B000BDB654
    http://brunnerent.com/Tools/Portfoli...?iPageNumber=1
    http://www.eztube.com/connectors/connectors.html
    You could even get a connector like this...
    http://www.eztube.com/images/connectors/100-305d.jpg
    and then weld a baby pin to a 1" piece of aluminum square tubing for use with c stands.
    If you wanted to add legs to it so it could stand up on its own, you could even use a connector like this...
    http://www.eztube.com/images/connectors/100-317d.jpg
  4. Collapse Details
    #44
    Junior Member
    Join Date
    Sep 2012
    Posts
    1
    Default
    I registered for the sole reason of thanking you for these instructions, they were easy to follow and concise. I know have an effective and cheap butterfly, while remaining professional enough in look that I can bring it anywhere.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
