Page 3 of 30 FirstFirst 123456713 ... LastLast
Results 21 to 30 of 292
  1. Collapse Details
    #21
    Senior Member Tom Roper's Avatar
    Join Date
    Jun 2008
    Location
    Denver, Colorado
    Posts
    1,310
    Default
    I want to be clear about this Sony, please hurry before I face undoing a pre-purchase un-cancellation that ships before the model I really want gets rumored.
    2 out of 2 members found this post helpful.
  2. Collapse Details
    #22
    Senior Member ahalpert's Avatar
    Join Date
    Apr 2011
    Location
    NYC
    Posts
    3,514
    Default
    Quote Originally Posted by TheDingo View Post
    It looks good, but I know it's going to be crippled in some way to ensure that it won't compete with Sony's higher end models. My guess is no IBIS and overheating when shooting longer videos. Still, I'm curious to see what the actual specs are.
    I doubt it will overheat if it's a "cinema" camera. Certainly, compared to the A7SIII, if it doesn't have IBIS then it should be even easier for them to dissipate heat. And the a7siii has only minor overheating issues
  3. Collapse Details
    #23
    Senior Member
    Join Date
    Oct 2008
    Location
    Bristol, UK
    Posts
    10,430
    Default
    Well it looks less stupid than the C70 but Im not sure where the I/O ports are!
  4. Collapse Details
    #24
    Senior Member
    Join Date
    Aug 2008
    Location
    Ottawa , Canada
    Posts
    760
    Default
    Looks like it could be an A7SIII without a viewfinder but metal body with attachment points so no need for a cage etc. So without viewfinder, maybe IBIS etc it could be cheaper than the A7SIII and compete with the box cameras that are out there .
  5. Collapse Details
    #25
    Senior Member
    Join Date
    Oct 2008
    Location
    Bristol, UK
    Posts
    10,430
    Default
    It will certainly need a cage. Also note that the hotshoe is a bit higher than the 1/4 females which will mean a bit of design in the cage
  6. Collapse Details
    #26
    Senior Member
    Join Date
    Aug 2008
    Location
    Ottawa , Canada
    Posts
    760
    Default
    Quote Originally Posted by morgan_moore View Post
    That depends on projected use I think. On a drone or gimbals maybe not. The Mi shoe for Sony XLR unit and plenty of mounting for monitor too not sure needed for tripod either. Do you have a use case for cage?
    1 out of 1 members found this post helpful.
  7. Collapse Details
    #27
    Join Date
    Apr 2011
    Location
    NYC
    Posts
    3,514
    Default
    Quote Originally Posted by Ron Evans View Post
    I'm with you. I've been cage-free all my life, although I generally rig less on than some of these blokes
  8. Collapse Details
    #28
    Senior Member
    Join Date
    Oct 2008
    Location
    Bristol, UK
    Posts
    10,430
    Default
    Firstly any single hole camera at the bottom needs sorting if you want it not to twist under forces of zoom or focus motor. This usually drives on cagewards.
    Most hard rigging needs clamping top and bottom, my own uses mean changing configuration quickly, especially Movi needs a clean top.
    My personal 'standard' is to have an 'arca' on the top and the bottom of my cameras.
    This enables me to clamp it top/bottom when on my Movi and when off the movi I add a handle or transmitter or monitor or whatever up top.
    If I hang the camera from a jib not flipping it does help.
    Arca top and bottom usually needs a cage
    My z6 now has a homebuild flat plate with 2 3/8 holes ready for an arca to be mounted solid https://www.instagram.com/p/CKhCI-lB..._web_copy_link
    Here is a z6 before I built that with no top attachment. It will vib and probably spin with motor torqe.
    https://www.instagram.com/p/BuO07wzA..._web_copy_link
  9. Collapse Details
    #29
    Senior Member
    Join Date
    Aug 2008
    Location
    Ottawa , Canada
    Posts
    760
    Default
    We have no idea what the bottom is like as I have only seen two photos. There look to be mounting on top and side of those photos so I assume there may be on the other side too as well as the bottom. Smallrig make lots of fittings that I have put on my Ninja V rather than a full cage and may well do the same for these camera. We will have to wait and see what it is actually like. I started with a Smallrig cage for my GH5 but in the end since all of my projects are on tripod have just mounted the Ninja V and magicarm to the tripod and do not use a cage on any of my camera now finding the tripod a better mounting point.
  10. Collapse Details
    #30
    Senior Member scorsesefan's Avatar
    Join Date
    Jul 2005
    Location
    Queens, New York
    Posts
    2,042
    Default
    +1. Looks like a re-housed a7siii...
Posting Permissions
  • You may not post replies
  • You may not edit your posts
