I am partial to the cheapo Canon EF S 10-18mm f.4.5-5.6 IS STM. It's slow is it's only downfall but it's a great lens for handheld wide stuff, I've shot some things with it that made it to theatrical
and it looked great on the big screen. I too find the sweet spot to be about 13-14mm on the C200's S35 sensor. 10-12mm distorts people too much but at 13-14mm if you keep people away from the edges,
not bad.
Thread: Good wide angle zooms for C100?
Results 11 to 15 of 15
11-26-2020 10:23 AM
It's a business first and a creative outlet second.
G.A.S. destroys lives. Stop buying gear that doesn't make you money.
- Join Date
- Sep 2012
- Posts
- 401
11-26-2020 01:23 PM
Dreams can come true.
It's rehoused Nikon 14-24 f/2.8 AF-S NIKKOR G ED N (Ruby).
If you are fine with focusing in "wrong" direction, using adapter to mount it on your C100 and lacking some other minor cinema features.
- Join Date
- Sep 2020
- Posts
- 5
- Join Date
- Dec 2007
- Posts
- 72
12-02-2020 06:04 PM
How about the Tamron 15-30 VC? It's 2.8 and could give you the range you're after (combined with a 24-70) without shelling out for an 18-80 (Hey, and 1 stop of light to boot). I've read remarkable things--when it works! It's fairly rectilinear (the straighter lines you're looking for) and considered quite sharp. BUT Tamron G2 lenses don't play well with the C200 and C300 mkii DPAF. However, I believe they work fine with C100 (83% sure). But PLEASE don't trust me on this. Also, the Tamron's focus in Nikon direction, which can be aggravating to use (but don't the Tokina's as well?) But if you often use AF, or if your 24-70 is also Tamron, then no problem. I've wished for awhile that it could play nice with my C200. Nothing else that I know of is that wide, bright, sharp and stabilized--even if you spend 10x the money.
- Join Date
- Dec 2007
- Posts
- 72
12-02-2020 06:19 PM
OTOH, If you don't need all the range, I think the Canon 17-55 is an amazing workhorse. I wish to H they would issue an update to this lens. I know Puredrifting on this forum doesn't love it, but it does a lot that nothing else does. Focus is pretty quick and quiet, unlike the equivalent Sigmas, Tamrons or Tokinas. It's 2,8 and the both the AF and IS are solid. You might want to buy 2 to compare and return the lesser copy. And also send it in for cleaning every 2 years (it breathes like a MF and collects dust like they're Poke balls). And then if you need wider with low distortion, get something like a Venus Optics Laowa 12mm f/2.8 Zero-D and put it on a tripod, gimbal or slider.
