That is a future thing maybe. Not that I really care about the gaff being there.
These are the 3d printed mock ups. The original will be CNC.
Appreciate the support! Yeah, making some nato rails on side as well to hard mount the E5 as next step.
C
Thread: Camera cage
Results 11 to 20 of 23
- Join Date
- May 2020
- Location
- Los Angeles
- Posts
- 110
11-30-2020 09:22 PM
IATSE Local 600 Western Region – 1st Assistant Camera
Associate Member of the S.O.C.
- Join Date
- May 2020
- Location
- Los Angeles
- Posts
- 110
12-16-2020 08:36 PM
Update.
Design is done mostly.
It will be made a bit skinnier, but it is hard to 3d-print that so mockup is a bit thicker.
CIATSE Local 600 Western Region – 1st Assistant Camera
1 out of 1 members found this post helpful.
- Join Date
- Oct 2019
- Posts
- 71
12-19-2020 09:30 AM
Wow!! This is awesome! I love the initiative.
Im kinda diggin' the red color haha, (I know that its just the 3d print) but some color options on the final machined pieces could be pretty cool for self expression / individuality, just a thought. Also do you think adding the extra metal would adjust the internal temperature?
I hope you will make these available for purchase : ) I'd definitely be down to support.
- Join Date
- Oct 2010
- Location
- USA
- Posts
- 771
12-19-2020 03:16 PM
The vents aren't blocked at all.
- Join Date
- May 2020
- Location
- Los Angeles
- Posts
- 110
12-22-2020 12:02 AM
As Yachacha is saying, we aren’t covering vents so it should not be any issues.
I am talking to some CNC people right now, and final version might be made in UK by RatWorks, and the. You can order WHATEVER color your want!!
Regardless I’ll make sure there is a source so the community can buy them!
- Join Date
- Oct 2019
- Posts
- 71
- Join Date
- May 2020
- Location
- Los Angeles
- Posts
- 110
12-24-2020 06:34 PM
We are debating going back to the drawing board and remake the top to include several lemo power outputs.
I am currently redesigning my rig to have a wet dock with a box attached on the back, in the box have 2 AJA 3gm recorders, and behind that the battery plate. And the wet dock power is for the AJA boxes.
However, if I go in steadicam there is not enough outputs to power recorder, terradek, and FIZ. The side panel just outputs 4A and that just powers 2 of them sadly.
- Join Date
- May 2020
- Location
- Los Angeles
- Posts
- 110
01-05-2021 02:48 PM
UPDATE!
The is no issue but getting the top dock was more work than we thought. We ended up taking apart a SRW-1 to be able to have power coming out
And the top plate is getting it's redesign.
- Join Date
- May 2020
- Location
- Los Angeles
- Posts
- 110
03-04-2021 05:55 AM
UPDATE!
Been busy working, actually shot some stuff on the F35. But the cage is coming along.
As well as a powered top handle with 2-pin LEMO *and* P-tap
This side plate below seems almost done, now we are going to send it for prototyping in CNC.
Side_1.jpg Side_2.jpg Side_3.jpgIATSE Local 600 Western Region – 1st Assistant Camera
