Thread: Camera cage
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
  1. Collapse Details
    Camera cage
    #1
    Senior Member
    Join Date
    May 2020
    Location
    Los Angeles
    Posts
    110
    Default
    Hi!
    I know this camera is quite frankly a bit too old for anyone to look into developing anything new for this camera, so if it someone, it has to be oneself.
    Working with cinema professionals in LA I have been fortunate to befriend a few people that owns 3d printers, cnc machines, and well, anything you need to make anything. Luckily they have enlisted their help, and I am looking into designing a camera cage for the F35 looking similar to what ARRI made standard for the Alexa mini. First versions will probably be on the heavier steel side, but my goal is to make it as lightweight as possible.
    I have a few questions though.
    My goal was to build it in so the Odyssey 7Q could be attached to the cage on the “dumb side”, and therefor act as a assistants panel sort of. Or is there a better placement you think?
    Second question, and I just want to have this cleared once and for all. If I attached 2 IF boxes to the camera, could I record 4444 in 50p then? Or is the 7Q not possible to record that? (It would alter the design if i could figure out a way to make merge 2 boxes into 1).
    Finally.
    Are there any diagrams, step by step guides, or videos on how to take the camera apart? I am pretty nifty with a screwdriver, but I sort of want to know if there are any irreplaceable ribbon cables I have to watch out for.
    //C
    IATSE Local 600 Western Region1st Assistant Camera
    Associate Member of the S.O.C.
  2. Collapse Details
    #2
    Senior Member
    Join Date
    May 2020
    Location
    Los Angeles
    Posts
    110
    Default
    UPDATE!
    After speaking to a few here, and actual cage makers, the work might be overdoing it, and the size of the 7Q isn't ideal.
    And spoken to my AC friends, we have figured out an prototype top handle. Working title FTP-1, to replace the top.
    The back part is meant to house the AJA 3GM. Or potentially we might repurpose the IF box and remove the the XLR part completely.
    Now for this build we have decide on a a few things.
    -Using the PIX-E5 for size/weight
    -PIX E5 has a quicker and easier storage solution
    -PIX E5 is more durable
    -TimeCode can be sent in using 3.5mm, and therefore possible to actually match it
    -The FTP-1 ledge can be used to house terradek, or MDR, if not housing the AJA 3GM.
    C
  3. Collapse Details
    #3
    Senior Member
    Join Date
    Oct 2010
    Location
    USA
    Posts
    771
    Default
    There are a few of these type of dry dock plates floating around:
    Personally I try to go the other way, F35 is too tall, I've removed the top dock completely from my cameras which is pretty easy compared to trying to reverse engineer the dock mount.
    1 out of 1 members found this post helpful.
  4. Collapse Details
    #4
    Senior Member Grug's Avatar
    Join Date
    Apr 2007
    Location
    Melbourne, Australia
    Posts
    4,230
    Default
    I would look at getting a simple cheeseplate on top, then adding something like Smallrig's 1979 top handle (which is a terrific, cine-orientated design, and gives you 15mm rod clamps and a tonne of Arri-locating 3/8" holes). You can rig everything you need to off a handle like that.
  5. Collapse Details
    #5
    Senior Member
    Join Date
    May 2020
    Location
    Los Angeles
    Posts
    110
    Default
    Quote Originally Posted by Grug View Post
    Yeah. This is our aim.
    Cheese plate, a small rig handle, abs locating pins for more things like MDR.
    We are still making a side plate. Because that will be the best way to make a permanent lock-in mechanism for the PIX.
    My biggest hurdle right now is figuring out run/stop, preferably from operators side. And then later, time code.
    C
  6. Collapse Details
    #6
    Senior Member
    Join Date
    May 2020
    Location
    Los Angeles
    Posts
    110
    Default
    Quote Originally Posted by yachacha View Post
    I honestly doesn’t think size is too big. And I want to be able to move the IF box if necessary. Some steadicams are different.
    Also I am having Fischer cables made so I can use the power out for accessories.
    C
  7. Collapse Details
    #7
    Senior Member
    Join Date
    May 2020
    Location
    Los Angeles
    Posts
    110
    Default
    Update!
    The plate has gotten its final form.
    Also, removed the handle attachment so now I can add a small mounting point for the EVF.
    C
  8. Collapse Details
    #8
    Senior Member
    Join Date
    May 2020
    Location
    Los Angeles
    Posts
    110
    Default
    *UPDATE*
    My AC has gotten to the side of the camera now, and it is getting interesting!!
    //C
  9. Collapse Details
    #9
    Senior Member
    Join Date
    Oct 2010
    Location
    USA
    Posts
    771
    Default
    rip off that gaff tape over the bottom viewfinder port and make yourself a cover while you are at it.
    These are 3d printed?
  10. Collapse Details
    #10
    Default
    Loving the new plates. exactly the direction I would have loved to take my build at the time! (though I like the way Yachacha leveled off the top. )
    This is exciting stuff and looks very nondestructive, which I suppose is a plus!
    Inspiring man! great work!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
