Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
  1. Collapse Details
    #11
    Senior Member
    Join Date
    Oct 2011
    Posts
    497
    Default
    Quote Originally Posted by morgan_moore View Post
    I think the point of 32bit float is that no order of operation or which tools you use make any difference - you cant get it wrong like that in Resolve.
    Moving from log to 709 always helps you to see the noise that is in a file - simply you are boosting contrast and sat - which exagerates, to the eye, noise.
    IMO noise in shadows is made nicer with reduction in shadow saturation
    Beyond that you need to play with noise reduction. IMO properly shot footage rarely needs NR.
    so if I use primaries or contrast or shadows or curves all should be the same? only the raw tab for raw footage would have benefits?
  2. Collapse Details
    #12
    Senior Member
    Join Date
    Oct 2008
    Location
    Bristol, UK
    Posts
    10,055
    Default
    I think everything is all the same.. but Im not sure about raw.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
