Results 1 to 4 of 4
  1. Collapse Details
    Sony PMW-F3 bayonet strength?
    #1
    Default
    What is the maximum weight of a lens you can put on Sony PMW-F3? I see that some people use rails which provide additional support for lenses. I don't have such rails and I wonder if its ok to put a lens like Nikon 24-70 on this camera without any support? Thanks.
  2. Collapse Details
    #2
    Senior Member
    Join Date
    Feb 2009
    Location
    Long Island
    Posts
    8,941
    Default
    If weight information is published by Sony then it would be in the manual.
    But a 24-70mm is fine. Many use rails for the client impression they provide, and also for other accessories like follow-focus systems. Most of the time a lens support is used for mental appeasement.
    1 out of 1 members found this post helpful.
  3. Collapse Details
    #3
    Senior Member
    Join Date
    Dec 2011
    Location
    Florida
    Posts
    2,478
    Default
    I routinely used PL lenses, without any extra support, that weighed more than 5 pounds when I owned an F3.
  4. Collapse Details
    #4
    Default
    The Sony FZ mount found on the F3, F5 and F55 is very strong, no worries, especially with a DSLR lens. If you are using Nikon, you should really get the Optitek Nikon prolock adapter, which gives you cinevised iris for all Nikon glass.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
