Page 4 of 19 FirstFirst 1234567814 ... LastLast
Results 31 to 40 of 190
  1. Collapse Details
    #31
    Senior Member
    Join Date
    Jun 2008
    Posts
    911
    Default
    I wasn't thinking audio LTC.
    I thought GH5 had a non-audio connector that synced camera clock if fed.
  2. Collapse Details
    #32
    Senior Member Erik Naso's Avatar
    Join Date
    Jul 2008
    Location
    San Diego
    Posts
    4,369
    Default
    Quote Originally Posted by Gweilo66 View Post
    It does and after you jam it it drifts a lot making it unusable.
  3. Collapse Details
    #33
    Senior Member puredrifting's Avatar
    Join Date
    Nov 2004
    Location
    Los Angeles, Ca.
    Posts
    10,612
    Default
    Quote Originally Posted by yoclay View Post
    If you are going to put TC in a cam like this (read X-T3), it would be darn nice to be able to at least jamsync it. I mean how hard is it that ? Not looking for clean sound or expecting a clock to run flawlessly for days on end, but certainly helpful when using these things as B cams...which is let's face it, often what they are.
    We use the Tentacle Sync Es with our X-T3 and C200 on the 3.5mm Ch3-4 input to sync them to our Sound Devices Mix Pre recorders and they work like a dream, painless and seamless.
    They even have a built in scratch mic. You don't need a dedicated TC input honestly, it's nice to have but as Eric notes, cameras like these usually have
    crappy, unreliable TC functions as well. We don't shoot many events so I have not checked multi-hour drift but for normal shooting, starts and stops, we set
    our main Tentacle to TOD TC and let it go, utilize the Tentacle software to sync it all up, it exports an XML. FCP X opens it and voila, everything is in sync.
    The dark secret is that the mulitcam function is so good in FCP X, we don't even use TC for multiple cameras, we just sync using scratch audio and that works great too. We only use the Tentacles for footage
    we shoot for clients or when we throw the SD Mix Pre 3 in the mix since it doesn't have it's own TC generator like the Mix Pre IIs but it accepts TC from the Tentacle and stamps the files.
    It's a business first and a creative outlet second.
    G.A.S. destroys lives. Stop buying gear that doesn't make you money.
  4. Collapse Details
    #34
    Senior Member
    Join Date
    Jun 2008
    Posts
    911
    Default
    Quote Originally Posted by Erik Naso View Post
    You mean with an attached box feeding it continuously?
  5. Collapse Details
    #35
    Senior Member
    Join Date
    Apr 2008
    Posts
    3,749
    Default
    Quote Originally Posted by puredrifting View Post
    Internal audio on consumer cameras to me is pointless, all mirrorless cameras sound like garbage compared even to the Tascam DR10L and I am sure compared to the upcoming Tentacle 32-bit recorders, much less a Sound Devices or Zoom F6, so
    what's the point besides a tiny bit of convenience? Even with an audio extension unit, if the mic preamps, A/D and other audio circuitry are crappy, why bother? At least cameras like the FS7, C200/300MKII have usable internal audio, if not great,
    but the mirrorless? Not for me.
    I am all for high end audio gear but the GH5 with the audio unit and a good mic has produced some nice audio for me. Useless? I think that is a bit harsh. We all work at different levels and to me, I do not think most clients would notice the audio captured properly in an interview between a GH5 w/XLR, Zoom F6 or a SD setup. IF one has a client that would notice then using a cheap mirrorless camera on that shoot is probably pointless imho. With some post work the 24bit files can be made to sound good. It is all relative.
    It is more than a little convenience - batteries, cable connections, mounting etc... Some times it is a pain.
    I agree it looks like Fuji would probably not have an XLR unit, but I have to ask - why not? It is a $200-$300 add on that turns the camera into a way better tool for video. = more sales...
    3 out of 3 members found this post helpful.
  6. Collapse Details
    #36
    Senior Member
    Join Date
    Dec 2007
    Posts
    2,628
    Default
    TC in all hybrids that offer it is not usable. The GH5 drifts almost immediately making it unusable. If you need TC then I think using a different camera is a better choice.
    Changing an entire camera system (especially the lensing) because of the TC is not realistic.
    I am not trying to find a solution to what currently doesn't properly exist.
    (I own four Tentacles and it's often a PIA.)
    I am talking about the need of manufacturers to make it exist.
    We are reading 6K pixels worth of image at 25, 30 or 60 fps nowadays.
    Honestly, how difficult is it to have a decent clock and jamsync ?
    You want to sell multiple cameras ? Strikes me as obvious.
    1 out of 3 members found this post helpful.
  7. Collapse Details
    #37
    Join Date
    Nov 2004
    Location
    Los Angeles, Ca.
    Posts
    10,612
    Default
    Quote Originally Posted by Bassman2003 View Post
    It probably is harsh but I've been dealing with this since the dawn of the digital revolution. It's a whole chain of priority.
    Manufacturers build garbage audio into cameras because they don't think users care or will notice the difference.
    Users don't care or notice the difference until they use something quality and then realize how bad the audio is from cameras.
    Here's my main beef. We used to sort of let is slide because "the audio that actually gets used is coming from the sound mixer" so camera
    audio wasn't that important, you could use it in a pinch or if you were lazy but if you wanted good sound, you conformed your audio and used
    what the sound mixer recorded. FF a few years and now few of us are hiring sound mixers anymore unless we have a well financed project.
    So that means today that much more of the in-camera audio is what is used for the final product. Even the cheapest digital audio recorders
    tend to objectively sound so much better than any prosumer camera, I discovered this with both the GH5S and the our X-T3. We've been using
    both on gimbals the past couple of years with the Tascam DR10Ls as well as our pretty inexpensive SD Mix Pre 3. There is simply no comparison.
    Of course, it's how good is good enough and for many clients, they don't care or don't have an ear so possibly mirrorless audio is good enough.
    But if you are audio focused, as I am, when you do a rough cut with camera audio and then conform to the audio even from your cheapo Tascam
    DR10L and A/B is back and forth, there is no comparison. It's not that modern mirrorless have as much hiss and noise as we used to have to put
    up with from VX1000s, it's that cheap mic pre-amps (they literally cost as little as .50), A/D and D/A convertors have hardly any dynamic range,
    there are large amounts of intermodulation distortion, channel bleed from poor channel isolation. And now we have 32-bit floating point recording
    on very affordable recorders which takes externally recorded audio up another two or three notches above the garbage camera audio.
    If in camera audio suffices for one's need, more power to them, it's a little faster, easier and more convenient. But double system sound isn't
    really very difficult to implement into a workflow, I did it for two years when the 5D MKII and MKIII were our main low budget cameras and that was
    with no timecode, just a handclap or dumb slate. The only workflow where it doesn't work is if you hand off media directly to clients after a shoot.
    I've had clients who are cool with doing that but many clients aren't, especially if they need to go to air or the web immediately like with EPK and
    junkets.
  8. Collapse Details
    #38
    Senior Member
    Join Date
    Jul 2007
    Location
    Toronto
    Posts
    6,985
    Cool
    I'm pretty happy with the audio my GH5 records when using the Panasonic XLR adapter and a Sound Devices MixPre-D to feed audio to the camera.
    ( the MixPre-D pre-amps are far better than any Tascam gear I've owned or my cameras by themselves )
  9. Collapse Details
    #39
    Default
    I do not argue with your ear. I just don't see the manufacturers' logic. How much are good pre-amps?
  10. Collapse Details
    #40
    Senior Member
    Join Date
    Apr 2008
    Posts
    3,749
    Default
    I can't say I disagree with you Dan but it sounds like you are referencing using the internal mic of the camera. Nobody would argue that there is better but in my experience, the GH5 with the XLR unit is pretty good, especially with post treatment. I guess my point is, good enough for work that includes using a $2,000 camera. Which is a lot these days!
    I would like to convey to all of the manufacturers that this level of audio for all of the top tier mirrorless cameras is needed for them to be complete video tools. Because the people that buy and use them probably do mid to low level paying work! So if the bots are reading this - Fuji, make an XLR audio adapter.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
