Page 3 of 6 FirstFirst 123456 LastLast
Results 21 to 30 of 52
  1. Collapse Details
    #21
    Senior Member scorsesefan's Avatar
    Join Date
    Jul 2005
    Location
    Queens, New York
    Posts
    1,663
    Default
    Adding to what Puredrifting said is the issue of interviewing. IMO adding anything that is going to create a barrier between you and your subject is a negative -- like headphones for monitoring a wireless system. Ideally, you have a sound mixer on set, but that's not always possible. Yes, there are things that can go wrong with lav recorders, but IME the things that can go wrong with wireless systems, including dropouts and RF interference are far more common. Wireless lav recorders are a bit of a leap of faith, but in certain situations it's a risk I'm willing to take...
  2. Collapse Details
    #22
    Senior Member puredrifting's Avatar
    Join Date
    Nov 2004
    Location
    Los Angeles, Ca.
    Posts
    10,373
    Default
    Quote Originally Posted by scorsesefan View Post
    Amen. Same here. As long as you learn how to effectively rig lavs (I am hyped on the Rycote Overcovers), I have not lost or ended up with unusable audio in over a year of using the Tascams. The Tascams sound amazingly good for the money, they also record a -6dB or -12dB safety channel so as long as your battery doesn't die (these record all day on a single AAA, unlike wireless systems that gobble through a lot of batteries) and you don't rig your lav badly, you end up with very usable audio. Not as good as a boom. Not as good as from a Lectro. But IMHO, usually better than what we get from lower end wireless, less noise and hiss. The 32-bit from the Tentacles will make even a safety channel not needed.
    It's a business first and a creative outlet second.
    G.A.S. destroys lives. Stop buying gear that doesn't make you money.
  3. Collapse Details
    #23
    Senior Member
    Join Date
    Mar 2012
    Location
    Australia
    Posts
    1,293
    Default
    Quote Originally Posted by junct View Post
    I've used the 702 before, and it's a good piece of equipment. But I can't imagine easily being able to wrangle it while recording as a OMB, and actually making good use of it's capabilities?
    I like the simple wired lav set up with the Tasam Dr10 for it's simplicity. I get better sound with the lav compared to a generally better sounding shotgun mic, simply because as a OMB I can get the lav into better positions. But for shoots with more movement, and the need to monitor audio, a wireless feed back to a simple recorder would help a lot.
    Just a note on the SD recorder, when I owned a gh4 I used the golf tee looking pins to attach a key ring. Then to each key ring I clipped a carabiner. I attached them to two belt loops on my pants. I also taped a sony wireless receiver to the recorder. The limiters were awesome for the project, the audio was pretty hot but still struggled to clip. Everyone will have a different definition of what's easy to wrangle though. It was a good enough solution for recording separate audio. I just made sure I recorded to both devices no matter what then syncing the clips was easy enough. Obviously this was an extremely low budget project but my point is maybe you can revisit any recorders you've dismissed if there's a chance you can make it work by getting creative with how it's carried.
    I'd really like to try something similar with an action cam eg gopro/insta360 - I think it'd be cool to have pristine audio while shooting video with this tiny cube in your hand/cube on stick.
  4. Collapse Details
    #24
    Senior Member
    Join Date
    Oct 2008
    Location
    Bristol, UK
    Posts
    9,698
    Default
    my SD - I drilled a couple of holes in the lid and added a rod mount. The configuration was shoulder mount with my camera. One can take an output and feed the camera to get one file, with a backup audio file
  5. Collapse Details
    #25
    Member junct's Avatar
    Join Date
    Mar 2014
    Location
    New Zealand
    Posts
    73
    Default
    Quote Originally Posted by puredrifting View Post
    I'm using the Tascam DR10Ls until the Tentacle releases. For me, OMB doc shooting, worrying about wireless, my Mix Pre3, bag, batteries, that is just too much gak and gear to deal with as I need to be a good interviewer/producer and cinematographer too. Syncing multiple subjexts is SUPER easy in FCP X, not sure why anyone couldn't make that all work but perhaps Premiere and Resolve don't sync audio as well? Doing a shoot this weekend with one of our main talents running a meeting. Will have a Tascam DR10L on her, two camera mics on two cameras and we get what we get. We don't have budget or resources to have a sound mixer. I could be the dedicated sound mixer myself, but not while doing camera, interviewing, etc. I've been running the Tascams now for a year and half on this project. So far, bullet proof, they've been amazingly good and reliable and we always get at least usable and sometimes really great sound. The Tentacles, when they hit, will be a timecode version of the DR10L on steroids with the 32 bit.
    Wireless is fine for certain situations. But OMB/run & gun is not one of them as far as I'm concerned, unless you have a sound mxier. Too many gotchas, variables, UHF/2.4Ghz issues. I have two of the Røde wireless, they are great and we have the Deity Connect which is also good. So far, no problems with the Deity battery life, although that could be a factor if you are shooting 12-14 hours straight, but we rarely do, especially with wireless. I rent the Lectros, they are the best but at $6k per pair, they should be the best.
    I think a post of yours was what lead me to the Dr10s in the first place.
    I don't mind syncing stuff in post, I've done it on hundreds of projects. But that doesn't mean that having one less step wouldn't be nice. Of course, I'd rather spend an extra few minutes in post than have to trouble shoot scanning issues etc when I have half an hour to get an interview with a client.
    The Tentacles sound promising. I need to read a bit more about them, as I wasn't familiar with their timecode solutions, but they might make a better long term investment at this point.
    Quote Originally Posted by NorBro View Post
    Didn't read through this entire thread as the audio pros here are always great (so not sure if anyone mentioned this), but just wanted to add that I never enjoyed audio more in life then after purchasing a F6 and recording 32-bit float.
    It's a pastime of mine recovering blown audio or key-framing difficult dialogue.
    I can tell you about 200 amazing camera improvements that happened in the last decade, but not sure any of them are as significant as this audio breakthrough from last year.
    Interesting, I'm only catching up now on the last couple of years of audio tech development.
    Quote Originally Posted by Alex H. View Post
    Missed this post earlier.
    Yes, I use a G3 system to send audio from MixPre-6 II to the camera.
    Thank you.
    I vehemently agree with this. Even using a boom op is noticably distracting (with subjects I've spent a few weeks with, I notice how much more relaxed they are if it's just me shooting with a DSLR, rather than a crew).
    I have noticed proper monitoring headphones add another barrier, too. But i've wondered if maybe some decent in-ears would work. Obviously they're never going to be as good as monitoring headphones, but maybe it'll be enough to hear if someone's rubbing a mic/a stick has become dislodged etc, while still being less invasive..
    In what situations do you find yourself using wireless lav systems over wired, and vice versa?
  6. Collapse Details
    #26
    Join Date
    Mar 2014
    Location
    New Zealand
    Posts
    73
    Default
    I've gotten better at rigging lavs, but do you have any good videos/articles on doing it? Most i've looked at are similarly vague. I used some of the overcovers when I last hired some lavs, and they made life a lot easier than messing around with different tapes to try and remove clothing noise.
  7. Collapse Details
    #27
    Join Date
    Mar 2014
    Location
    New Zealand
    Posts
    73
    Default
    What are you using for your on-camera mic set up? Are you running straight into the camera, through a pre-amp, with a dr10L, etc etc?
  8. Collapse Details
    #28
    Senior Member
    Join Date
    Feb 2009
    Location
    Long Island
    Posts
    6,531
    Default
    It's hard to imagine until you experience it. Just pretend or look back at any time your audio was too hot/distorted/modulated, and picture simply dragging down the dB bar in post and it being perfectly fine. You still need good mic placement and it won't help against any potential interference with future wireless systems, but especially great for a OMB handling a lot of tasks.
  9. Collapse Details
    #29
    Moderator Alex H.'s Avatar
    Join Date
    Sep 2008
    Location
    Knoxville, TN
    Posts
    8,099
    Default
    Worth noting that the MixPre II series also offers 32-bit float.
    Nobody notices audio... until it's not there.
    Find Me on Instagram
  10. Collapse Details
    #30
    Senior Member
    Join Date
    Feb 2009
    Location
    Long Island
    Posts
    6,531
    Default
    Some might even like the SD ones better (of course they’re great too), but not 100% positive if they have a built-in/addable proprietary camera plate (only the thread).
Posting Permissions
  • You may not post replies
  • You may not edit your posts
