Results 1 to 2 of 2
  1. Collapse Details
    Small Cables - A Better Way to Make Them
    #1
    Senior Member
    Join Date
    Dec 2010
    Location
    West of the Pecos
    Posts
    2,577
    Default
    You may have heard me complain about making small cables like 3.5mm. I've never liked the bent metal strain relief. Then I came across glue hot shrink tubing, which I had forgotten about. I feel like I have more reliable cables using two bits of adhesive-lined heat shrink. I put one bit over the wires and one bit over the shroud and cable. The glue bonds to everything around it. With the two bits, I think I have a significant improvement in the soundness of the mechanical strain relief on these small cables. You can see a bit of glue peeking out the end of the heat shrink tube.
    Funny color shift between shots using a phone camera.
  2. Collapse Details
    #2
    Senior Member
    Join Date
    May 2015
    Location
    Central NY
    Posts
    2,384
    Default
    Marine grade shrink tube is what most places will call it, or waterproof shrink tube. Might open up some buying options.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
