Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
  1. Collapse Details
    #11
    Senior Member
    Join Date
    Sep 2012
    Posts
    340
    Default
  2. Collapse Details
    #12
    Senior Member
    Join Date
    Feb 2013
    Location
    Sydney, Australia
    Posts
    844
    Default
    How many lip smacks have you got? If it's not an insurmountable number I just use a volume process tool to greatly reduce not eliminate the sound otherwise as someone else says it can end up sounding unnatural. It's just a process of finding them in the audio track and applying the process. Many decent audio editors, DAWs etc will allow you do accomplish this quickly and very easily and leave a natural sounding results. It really doesn't require any over complex manipulation. Doing it manually will will give you far better results than most automated processes as the volume and character of each 'smack' may be quite different due to thew words associated with any given 'smack.' Below is an example of a 6dB reduction of a sound. The benefit of doing it manually allows you to tailor the reduction smack by smack.
    Chris Young
  3. Collapse Details
    #13
    Senior Member
    Join Date
    Sep 2012
    Posts
    340
    Default
    If you value your time, get izotope, it's one click process.
    You even don't need to lasso it, just select the affected part of audio track and apply. It automagically erases it.
  4. Collapse Details
    #14
    Senior Member
    Join Date
    Feb 2013
    Location
    Sydney, Australia
    Posts
    844
    Default
    That's the problem erasing it. The result often doesn't sound natural. I find if you really want to deliver the best result there is no magical one click short cut, it requires work. The closest I have found in a tool is Spectral View as mentioned earlier. I've used this but I have not yet found any solution better than doing it properly on a sound by sound basis. The CTRL U 'Heal' tool in Adobe Edition is probably the quickest way of repairing these problems and you will notice I am saying repairing as there is no 'real fix' other than trying to minimize the issue at the recording time.
    Chris Young
    https://filmsoundhub.vsonicarts.com/...smack-removal/
  5. Collapse Details
    #15
    Senior Member
    Join Date
    Sep 2012
    Posts
    340
    Default
    I have quite the opposite experience with coughs, sneezes, walks, squeaking parquet flooring, inhales etc. in live recordings of classical music, where you can't minimize the issue.
    It erases them with one click without consequences.
    Just mark all affected regions and apply, one at the time.
    It's not one click for all appearances of unwanted noises in the length of the recorded piece.
  6. Collapse Details
    #16
    Senior Member Zim's Avatar
    Join Date
    Dec 2004
    Location
    Illinois, USA
    Posts
    3,280
    Default
    I see there is an Isotope Elements that is free offer now. Not sure if this fix is in there. Right now were there are lip smacking or he is clearing his throat and I can I just clip it and then add a picture of other video at that spot. It works pretty good because he stops talking. We are talking about a 97 year old man talking about Iwo Jima and the Battle of Guam.
  7. Collapse Details
    #17
    Senior Member
    Join Date
    Jul 2007
    Location
    Toronto
    Posts
    6,983
    Cool
    Quote Originally Posted by laverdir View Post
    +1
    Two years ago I shot a 20 minute interview where one of the interviewees kept hitting his knee on the underside of the table in front of him. I tried to get him to stop doing this, but I think it was a bit of a nervous twitch so I kept doing it from time to time. At the end of the interview I asked him to remain completely quiet but to give me a few knee bumps on the table. I then used RX6 to sample these knee bumps as the noise I did not want and had it go through my audio track to remove them. RX6 removed the knee bumps without effecting anything else, which was very surprising. I knew that the RX6 machine-learning was good, but I had no idea about how good it could be. If you can isolate a good lip-smack sample without any voice, you might try doing the same thing to see if RX7 can get rid of them for you.
  8. Collapse Details
    #18
    Join Date
    Dec 2004
    Location
    Illinois, USA
    Posts
    3,280
    Default
    Quote Originally Posted by TheDingo View Post
    +1
    Thanks Dingo, I don't know a thing about isotope. I saw where they are offering the elements as a free download. Is this RX6 or 7 in elements? It would be worth a try.
  9. Collapse Details
    #19
    Senior Member
    Join Date
    Jul 2007
    Location
    Toronto
    Posts
    6,983
    Cool
    Quote Originally Posted by Zim View Post
    I have no experience with the elements version of the RX editor, but you can download a working trial of the RX software to test with. This might convince you to spend the money if the solution is good enough. ( I originally bought RX6 to save me from a re-shoot at a hospital where the HVAC system was so noisy it was ruining the audio for a 5 person group discussion, so out of desperation I tried the RX6 trial to see if it could make a difference and it worked, so I bought it on the spot to save my original shoot )
  10. Collapse Details
    #20
    Senior Member scorsesefan's Avatar
    Join Date
    Jul 2005
    Location
    Queens, New York
    Posts
    1,711
    Default
    How distracting is it? If the audience accepts it as a subject's tick/mannerism maybe just let it be?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
