Page 1 of 33 1234511 ... LastLast
Results 1 to 10 of 328
  1. Collapse Details
    Sony announces FX9 4K camcorder with 6K fullframe sensor
    #1
    Senior Member indiawilds's Avatar
    Join Date
    Apr 2011
    Location
    New Delhi, India
    Posts
    1,287
    Default
    Sony announces new FX9 4k camera with 6k fullframe sensor
    Sensor: newly-developed 6K Full-Frame
    Dynamic range: 15 stops
    Output: 4K 4:2:2 in 10 bit. Initially UHD. DCI 4k will be enabled later in December 2019. FHD 120p via extension kit. 16bit raw with XDCA extension kit
    Dual ISO: ISO 800/4000
    7stop electronic variable ND filter
    Image stabilization: metadata generated by FX9’s in built gyros to decide shake compensation
    B&H lists it at $10998 USD
    What do you guys think? When every other camera is giving you 5.9k output the FX9 is 4K only. Will you miss 6K output?
  2. Collapse Details
    #2
    Join Date
    Apr 2011
    Location
    New Delhi, India
    Posts
    1,287
    Default
  3. Collapse Details
    #3
    Join Date
    Apr 2011
    Location
    New Delhi, India
    Posts
    1,287
    Default
    This is the official video from Sony https://www.youtube.com/watch?v=JO625L0qxGo
  4. Collapse Details
    #4
    Join Date
    Apr 2011
    Location
    New Delhi, India
    Posts
    1,287
    Default
    Some sample footage from Sony https://www.youtube.com/watch?v=U3wz2dNCeNQ
  5. Collapse Details
    #5
    Senior Member
    Join Date
    Nov 2013
    Posts
    349
    Default
    How much would it cost to be able to record RAW?
  6. Collapse Details
    #6
    Senior Member
    Join Date
    Dec 2012
    Location
    Berlin
    Posts
    1,461
    Default
    Quote Originally Posted by IanTheM View Post
    €2500 for the back, then whatever a recorder will cost. So I guess €4-5000.
    That to me is the biggest downside to this camera, the need of that extension to record raw.
    Sony NEX-FS700R | A7S | Odyssey 7Q+ | Atomos Ninja V
    Sony 24-70/2.8 GM, 70-200/2.8GM, SEL 50/1.8, 35/1.8, 18-105/4, FE 28-70 | Samyang 16, 35 & 85mm Cine
    Sachtler Flowtech 75 | Benro S8
    MacBook Pro 2018 6-core i7 2.6 ghz / 32gb ram / 512gb HD | macOS Mojave
    Hackintosh i7-8700K 6-core 3.7 ghz / 32 gb ram / 512gb NVMe / Radeon RX 580 | macOS Mojave
  7. Collapse Details
    #7
    Senior Member
    Join Date
    May 2011
    Posts
    284
    Default
    From the Newsshooter article it sounds like the whole RAW recording part of the camera isn't really worked out well yet:
    https://www.newsshooter.com/2019/09/...l-frame-sensor
    The XDCA-FX9 extension unit ($2500) will supposedly enable 16-bit RAW output, but it's not clear if this will be limited to 4K and 2K recording (which presumably would be a sensor crop when outputting RAW) or if they will enable full sensor 6K RAW output. And apparently this RAW output from the FX9 extension unit will not be compatible with Sony's existing AXS-R7 RAW recorder ($7000) which works with the F5, F55, and Venice. So I am not sure if they are planning on developing a new RAW recorder or working with 3rd parties like Atomos to enable RAW recording on their monitor/recorders.
  8. Collapse Details
    #8
    Senior Member Samuel H's Avatar
    Join Date
    Jun 2010
    Location
    Madrid, Spain
    Posts
    7,915
    Default
    Sounds like a mini-VENICE for $11k, just like the C500II sounds like a mini-C700FF for $16k. Both out of my price range but it's nice to see high-end image coming downstream.
  9. Collapse Details
    #9
    Senior Member Jaime Valles's Avatar
    Join Date
    Jul 2004
    Location
    New York City
    Posts
    2,004
    Default
    In my opinion, no on-board raw recording is a mistake. The fact that you need an external recorder in addition to the extension unit just to get raw from the FX9 puts it at a significant disadvantage compared to the Canon C500 Mark II.
    If you don't want raw, then this looks like a good camera. But I think Canon really hit it out of the park this time.
    Jaime VallÚs
    AJV Media
    Video, Photography & Graphic Design: www.ajvmedia.com
  10. Collapse Details
    #10
    Senior Member cpreston's Avatar
    Join Date
    May 2012
    Location
    Boston, MA
    Posts
    1,319
    Default
    Time code! Sound mixers and editors rejoice.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
