Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 40
  1. Collapse Details
    #21
    Senior Member
    Join Date
    Oct 2008
    Location
    Bristol, UK
    Posts
    9,504
    Default
    I mix Vlock and BPU and car batteries - I really dislike using anything else.
    All styles output 12-14.4 Volts which means that I can swap them about.
    With a built up rig I will use Vlock that will power everything.
    On my Movi I use BPU to save mass
    On my LEDs I use the car battery unless I want a quick shot in which case I will use Vlock.
    I also have a 240->12v transmofrmer
    I get really annoyed by anything (dslrs, some small acc.s that dont run on a nominal 12v)
    Not 12v.. focus sender, Movi mimic, movi
    I hate the older sony batts (7.2v) as they dont have a power meter.
    Brand? 10year old hawkwoods that are now getting a bit saggy.
    Next brand.. amazon may tempt me away from Hwoods.
  2. Collapse Details
    #22
    Senior Member James0b57's Avatar
    Join Date
    Dec 2008
    Posts
    3,909
    Default
    Quote Originally Posted by morgan_moore View Post
    A lot of well thought out choices in that.
    Is BPU the same as Sony L mount and NPF? If so, i am definitely going to start saying BPU.
    Vmount is a mixed bag, as i have had too many instances of the slightest knock and the cameras just loses power. But if i were building a v mount set for personal use, i could buy a plate and battery combo that locks properly. My best v mount experience has been sony to sony.
    B mount is the most solid connection i have found. But would have to field test... read spend money to find out...
  3. Collapse Details
    #23
    Join Date
    Dec 2008
    Posts
    3,909
    Default
    Quote Originally Posted by JPNola View Post
    I could never get past the name "Bebob". Same with "NICEYRIG".
    Totally agree.
    Also, they have a weird European style utilitarian plastic, that looks cheap. Their branding is odd, as it doesn’t look like they try.
  4. Collapse Details
    #24
    Join Date
    Dec 2008
    Posts
    3,909
    Default
    @morgan_moore
    It will be difficult to pull me away from my ab investments. But i am definitely seeing the standard getting long in the tooth.
    Bebob is kind of taking what i like about bricks, but also acting like a company that makes batteries for use in production.
    - most rigid and solid connection i have seen yet. No play.
    - dual power level read outs. One for the op side, and one for the AC side.
    - led light built in for mounting batteries on a dark set, or randomly needing a flashlight.
    - USB power out (so many gadgets onset these days, and makes a good phone charger for app tools)
    - the B mount is small enough base to make mini bricks without compromising the mount
    - reversable power-tap. That way you can route p-tap cables right or left, for an extra clean camera build.
    I’ve seen a lot of batteries at NAB and Cinegear this year, and some of them are just crazy with how many powering options they have built in, but Bebob (yeah i smirk when i have to say that word), has some of the best “production” focused features in a tidy brick. No frills, but all the features that make life easier.
    ...Now, if they can just change that name.
  5. Collapse Details
    #25
    Senior Member
    Join Date
    May 2015
    Location
    Central NY
    Posts
    2,234
    Default
    We use IDX plates and batteries with our students, never had a knock cause a power loss. If it is clicked in properly, it is good to go. I haven't tested other brands, and probably won't, why break a system that works so well? We've been using these since 2012, some of the cameras literally have over 1000 battery mount cycles and still work fine on the old batteries or the new batteries. It pays to buy brand name in this case. If they start making a mini V-mount, I might consider it to reduce weight, but we are already using 70wh batteries and won't see too much reduction.
    1 out of 1 members found this post helpful.
  6. Collapse Details
    #26
    Senior Member
    Join Date
    Oct 2008
    Location
    Bristol, UK
    Posts
    9,504
    Default
    Quote Originally Posted by James0b57 View Post
    Is BPU the same as Sony L mount and NPF? If so, i am definitely going to start saying BPU..
    They are very NOT the same. Look similar though.
    L/nfp are 7.2v and do not have charge level indicators and are from 2000s sony camcorders, currently used on amazon led panels etc.
    BPU may have been launched with the EX1 and also fit FS7, F3 and maybe fs5 z280 etc.
    They are 14.4v and have power level meters.
    Being 14.4 they interchange with Vlocks voltage wise (doubtless delivering less current and having shorter lives and are 1/3 of the size)
    SO if you want to power a monitor for 3 hours but be light and nimble you would pick a BPU, need it to run all day in the studio, use a Vlock.
  7. Collapse Details
    #27
    Join Date
    Dec 2008
    Posts
    3,909
    Default
    Quote Originally Posted by Greg_E View Post
    There are so many brands with v mount, it is most likely a case of ill fitting makes.
    IDX has a good reputation.
    Nothing was as bad as first generation Red bricks.
    Try grabbing the v mount while it is on the camera, and shake it about to see if you can force a problem.
  8. Collapse Details
    #28
    Join Date
    Dec 2008
    Posts
    3,909
    Default
    Thank you. I guess the one time i held an F3, i thought they were L mount batts.
    How do you hook them up to a monitor? A BPU plate adapter?
  9. Collapse Details
    #29
    Senior Member
    Join Date
    May 2015
    Location
    Central NY
    Posts
    2,234
    Default
    When that first came up a few months ago, I did that, as well as subjecting it to knocks in every direction. Even got out the old set and tried the same with one of them, still no issues. Just overall very pleased by there service life, and the manufacturer has always been quick to answer my questions, even when asking "stupid" things like is there a battery rebuild kit or service. They explained why they can't offer it, and it comes down to their flight certificate because of sealed batteries.
    The big 4 way chargers have been perfect two, we bought the ones without cell data because it was too much money. Some days those chargers go through a lot of work.
    Wish they made the Sony F style of battery and charger, had to go with Dolgin chargers for our cheap light kits.
    On the flip side, the news station I worked for put AB batteries through hell. We were often gluing cases back together, etc. That was in the days of nicads. I consider both AB and V mounts to be good quality connections.
  10. Collapse Details
    #30
    Senior Member
    Join Date
    Oct 2008
    Location
    Bristol, UK
    Posts
    9,504
    Default
    Yes Hawkwoods make a plate with 2 dtaps maybe 3.
    Most of my stuff- atomos SmallHd small leds etc have a 2.5mm power input
    My cables are mainly the same Dtap to 2.5
    I usually have 3 monitors going on set - operator- puller - anyone else
    Hawkwoods also make a four up charger which helps reduce cable hell
Posting Permissions
  • You may not post replies
  • You may not edit your posts
