Results 1 to 10 of 10
  1. Collapse Details
    mac for rendering prores in davinci
    #1
    Senior Member
    Join Date
    Jul 2015
    Location
    Bergen, Netherlands
    Posts
    1,224
    Default
    My workflow is mainly in Windows, I want to render 4K files to prores, which (older or cheap) mac can do the job?
    thanks.
  2. Collapse Details
    #2
    Senior Member
    Join Date
    May 2015
    Location
    Central NY
    Posts
    2,295
    Default
    Also on Linux?
  3. Collapse Details
    #3
    Senior Member
    Join Date
    Jul 2015
    Location
    Bergen, Netherlands
    Posts
    1,224
    Default
    Linux would be possible I guess, I can change Windows to Linux
  4. Collapse Details
    #4
    Senior Member
    Join Date
    Oct 2009
    Posts
    554
    Default
    Maybe a Mac Mini, but it would probably need to be souped-up, and wouldn't run the latest version of Resolve.
  5. Collapse Details
    #5
    Senior Member
    Join Date
    May 2015
    Location
    Central NY
    Posts
    2,295
    Default
    Third party encoders can also do this through ffmpeg, so I guess it depends on why you need prores.
  6. Collapse Details
    #6
    Senior Member
    Join Date
    Jul 2015
    Location
    Bergen, Netherlands
    Posts
    1,224
    Default
    An encoder will do too, but I could not find any yet. Seen ffmpeg does this work?
  7. Collapse Details
    #7
    Bronze Member
    Join Date
    Mar 2011
    Location
    Hollywood, CA
    Posts
    592
    Default
    Hackintosh can do it on your current computer.
    Buy a small/cheap second SSD along with a shuttle bay to easily swap it with your current boot drive, and it's easy to set up, too - the hardest part of setting up a Hackintosh is dealing with/saving an existing Windows installation, and if you take such out of the computer altogether temporarily when you run macOS then the whole thing becomes easy.
    FFmpeg might be even easier, however.
  8. Collapse Details
    #8
    Senior Member
    Join Date
    Jul 2015
    Location
    Bergen, Netherlands
    Posts
    1,224
    Default
    Thanks,
    I will try the ffmpeg route, read some warnings about it but, at least I'll try.
    The Hackingtosh is an alternative too, but I don't know if it is worth the effort involved.
  9. Collapse Details
    #9
    Senior Member
    Join Date
    Feb 2013
    Location
    Sydney, Australia
    Posts
    844
    Default
    Quote Originally Posted by Publimix View Post
    thanks.
    On Windoz if I have a request for ProRes files I just use Magix Vegas Pro. Worth buying if you have a reasonable amount of requests for good old ProRes. You will hear howls of indignation from Mac users who say it is not 'real' ProRes. I ignore those howls because any post outfit or network I have supplied Magix ProRes files to encoded on the Windows platform has never been knocked back. Two images below. The first shows you the ProRes 'Intermediate' render options and the second image shows you the typical analysis of the files produced using Magix Vegas Pro. On a fast PC the Magix Vegas render engine will also use hardware acceleration and push out the files pretty quickly. If required you can also do batch renders if you have a number of files to deliver.
    Chris Young
  10. Collapse Details
    #10
    Senior Member
    Join Date
    Mar 2011
    Posts
    341
    Default
    Try the free Shutter Encoder. I think it uses ffmpg, but in a nice user friendly GUI
    http://www.shutterencoder.com/en/
Posting Permissions
  • You may not post replies
  • You may not edit your posts
