I still have the occasional use for my HPX170 and wondered if it's possible to use the Panasonic wide angle conversion lens AG-LW7208 (intended for the DVX100) on the HPX170...both cameras have a 72mm thread mount but the opposing concave camera and convex lens glass meet before the threads do...maybe I could get a 72mm male/female extension ring to buy some distance between the 2 glass elements? Anyone done this before? Is it even possible? Advisable?
A manual test holding the additional lens in place looks good...
Results 1 to 5 of 5
- Join Date
- Jun 2007
- Location
- Temiskaming Shores, Ontario
- Posts
- 275
12-04-2018 02:53 PM
12-07-2018 07:19 PM
your theory with the step ring sounds right.. should work. You just need to buy yourself that space.
Cameras
RED SCARLET X 5K
LENSES
Sigma 18-35 F1.8 ART Zoom Lens
Recorders
AJA Kona 3 PCIe 4:4:4 Dual Link Card W/ Breakout Box
Panasonic AJ-PCD20 P2 Deck
Accessories
Astro DM-3000 HD-SDI Monitor
Benro Fluid Head Tripod
Chrosziel CLWAH-F4,5 Matte Box
12-08-2018 11:19 AM
It will work. Just buy yourself a cheap UV filter, and i mean cheap cuz you are going to knock or remove the glass. That should be enough of a spacer. I have done this before and it is usually cheaper than buying an actual spacer, if such a thing exists.
Just to be clear, you could use any type of filter, doesn't have to be a UV, just whatever is the cheapest.
- Join Date
- Jun 2007
- Location
- Posts
- 275
12-20-2018 10:33 AM
It totally worked! The HPX170 lives on!!!
01-09-2019 04:19 PM
Cameras
RED SCARLET X 5K
LENSES
Recorders
Accessories
