Page 3 of 7 FirstFirst 1234567 LastLast
Results 21 to 30 of 65
  1. Collapse Details
    #21
    Default
    Hey Phil, thanks for your concern. He uses pwm with a frequency >30000hz, I almost certain that all commercial applications from Litegear etc. use a similar approach. Also litemats are on coroplast. So sure, you gotta be cautious to stay within the limits of your leds but I don't see how your points are a problem for homebuilt lights. The big vendors cook with exactly the same stuff.
  2. Collapse Details
    #22
    Senior Member Jim Arthurs's Avatar
    Join Date
    Mar 2005
    Location
    Colorado Springs, CO
    Posts
    840
    Default
    Quote Originally Posted by Phil Rhodes View Post
    The other major problem I notice here is that he's using pulse width modulating dimmers which risk causing flicker at any frame rate with rolling-shutter cameras (which is almost all modern cameras) and especially at high frame rates.
    Not a problem with the high frequency dimmers, to demonstrate, I shot a test using those same Chinese 95 CRI LED strips that DIYPerks used... the first and probably only time I will shoot at 240fps with the GH5s...
    http://files.datausa.com/imageshoppe...ming240fps.mp4
    If anyone is curious, the full 16' string of LED's uses just above 3 amps at 12 volts at full brightness.
    I did use a higher amperage dimmer than he used, here's the link... (very expensive, BTW... )
    https://www.ebay.com/itm/12V-40V-10A...53.m2749.l2649
    It is possible to homebuild simple LED lights which don't have these problems and I have worked out an aliexpress shopping list to do it if anyone's interested.
    Of course we're interested, please share! Everyone is always interested and respects expertise and experience. I'm sure as heck not trying to produce "production ready" lighting, just create some secondary use products for personal projects, as I'm sure most are here.
    Regards,
    Jim Arthurs
  3. Collapse Details
    #23
    Default
    This 10A dimmer is awesome! Gonna order a couple.
  4. Collapse Details
    #24
    Senior Member
    Join Date
    Jul 2008
    Posts
    238
    Default
    Quote Originally Posted by Jim Arthurs View Post
    The higher the frequency, sure, the more likely it will be to work most of the time. I worry that a specific camera-light combination could easily cause problems that are difficult to predict and impossible to solve. Much of the time, PWM flicker will look like a fairly minor, almost invisible problem. You need to be looking at it on a waveform monitor that operates at full frame rate, which most in-camera and in-monitor ones don't. It can suddenly become a not-so-minor problem which you only see in the edit and which has the client screaming because once seen it's hard to unsee.
    One particular concern (not the only one) is that readout on rolling shutter cameras happens very, very quickly, more than fast enough to image 30KHz PWM cycles; nobody's ever going to make a PWM controller fast enough to overcome that.
    There are lights out there (the Astera tube stuff, with advanced chases and colour effects) which use dithered PWM, which has pseudorandom patterns in it to avoid repetitive flicker. That's a reasonable engineering compromise on something which needs a lot of control over a lot of different light sources, but it just isn't necessary on general-purpose lighting.
    Anyway, extreme caution advised. Commercial LED lighting options made for film and TV work are overwhelmingly not using PWM dimming for these exact reasons. The only exception I'm aware of is the Photon Beard Highlight which uses PWM in the very bottom of its dimming range, because it's intended for TV studios and it needs to be able to fade cleanly all the way down to black. Directly because of this, it's also more or less the only LED out there that actually can produce a smooth, clean fade to black...
    They're also not using resistive current limiting, other than on things like the Litegear tape which is built essentially the same way anything else is. On the other hand, Litegear aren't sticking row after row of it onto things to create a high power light. Although some people actually do. It works, though it isn't particularly efficient, because it burns so much power into heat. Usually it's being done for convenience, rather than because people are desperate for a low energy light.
    P
  5. Collapse Details
    #25
    Senior Member nyvz's Avatar
    Join Date
    Jul 2005
    Location
    New York, NY
    Posts
    2,180
    Default
    P
    Not sure I follow your point about readout speed. Who cares what the readout speed as long as the shutter speed is compatible? Are you saying you think a high readout speed will render some kind of artifact on its own on a flickering source regardless of shutter speed? I can't work out how that could possibly be an issue at normal shutter speeds.
    I agree that 30khz might not be fast enough for the highest of high shutter speeds, but in those cases you'd likely need all the light you can get and bypass PWM dimming by running at full output anyway. Even skypanels use PWM and need to be run in highspeed mode to bypass PWM, don't they? I do know Digital sputniks use voltage dimming but they have said fairly complex software curves are required to compensate for color shifts that occur through that method... I know some others do the same thing but use PWM to get the lower output dimmed modes.
    I've been using that 5x8A DMX LED Dimmer for a while, nearly every major manufacturer seems to have rebranded it in the past year (including Litegear). I believe it was originally made by Sunricher which is a Chinese company. Over a year ago when I found it it became very clear it was the only one of its kind in that it was affordable and had adjustable PWM up to 30khz. I put a couple of them in an studio install I did and was so happy with them I bought one and a 600W meanwell PSU to build my own light. I've been building some daisy chainable rollable modular RGBAW lights to hook up to it based on a 4'x2" form factor that could easily have a curved diffuser put on it to work as a "tube" (quasar rainbow-type) light. Getting a little fed up with soldering though so might just fall back on one big 600W RGBAW panel and maybe find a mounting system that accomodates not cutting strips at all. Problem is I seem to have shorted one of the channels, despite being fairly careful with my wiring and testing with my multimeter, I wonder if there is a way to recover it or if I'll have to buy another $80 controller. May have to just ditch the RGB functionality since the chance of me needing it in such a high powered light is somewhat lower...
    Noah Yuan-Vogel
    http://www.noahyv.com
  6. Collapse Details
    #26
    Senior Member Run&Gun's Avatar
    Join Date
    Jan 2014
    Location
    NC
    Posts
    3,641
    Default
    I haven't read the entire thread, but these last few posts bring up something. How exactly do the Quasar X-fade tubes work? I have a lot of them and the color temp is adjusted with an on-board control, but you use off-board, off-the-shelf dimmers to dim them similar to how I would with tungsten. I use off-the-shelf Lutron LED Lamp dimmers(recommended by Quasar) available at any Lowe's or Home Depot. Now, I haven't shot any high speed footage, but we haven't experienced any flicker or color shift with them at 23.98, 1/48 shutter.
  7. Collapse Details
    #27
    Senior Member
    Join Date
    Jul 2008
    Posts
    238
    Default
    Noah, if you have a rolling-shutter camera, if the light comes on or goes off during the readout period (which LEDs are more than fast enough to do) then you get a torn frame. If you make your PWM go very fast, you can even end up with stripes, or very very very fast, diagonal lines. I'm not aware of a PWM solution that attempts the sort of frame synchronisation that would be required to avoid that (in fact I'm only aware of one range of lights, the Outsight Creamsource, that offers shutter-awareness of any kind at all.)
    More to the point, even at 30KHz, you only have 625 PWM cycles per 24p frame, and the inclusion or exclusion of one of them represents more than 1 least-significant bit of variation. I'm not saying it can't work. Usually it does work, sort of, especially if you don't look too closely. I'm saying it's a bad idea which can bite you unexpectedly and in ways that are hard to predict and basically impossible to mitigate. It's also completely unnecessary in a world where current regulating DC-DC converters are trivially inexpensive.
    Run&Gun - I don't know specifically about Quasar tubes as they're rare and expensive in the UK, but various LED devices have been made which are aware of and work with conventional triac dimmers. It's a daft approach, from an engineering standpoint, since there are better ways to control LEDs which don't require a bulky triac dimmer assembly, but it avoids gaffers having to learn new things. The Visionsmith Relamp stuff works the same way. The technical challenge with doing this is that the device has to run its own internal electronics from the power that's coming in, which will have bits chopped out of it by the triac, and then they have to process that power for appropriate LED behaviour. For this reason they can have strange, twitchy behaviour at very low intensities, where there's barely enough power going in to run the electronics let alone the light. From what I've seen the Visionsmith stuff is very good but I haven't used it for real. Personally I'd rather use a current control (that is, a knob on the light, or a DMX/lumen radio/whatever interface) that's properly plumbed into the DC converter that's running the LEDs, which is cheaper, smaller, lighter, more reliable and has zero setup time.
  8. Collapse Details
    #28
    Join Date
    Mar 2005
    Location
    Posts
    840
    Default
    All these PVM concerns are a bit like giving a bunch of guys who want to deep fat fry Turkeys in the backyard the notes from a chef who is prepping a Quail for a five star restaurant. OF COURSE if you're renting or buying expensive lights for a high end or unique shoot you need to be spot on all these issues, but if you're just making some "fun" lighting for interviews and the what-not shot at normal shutter speeds, I WILL say there's no downside to the PWM dimmers when used on average video work under any conditions.
    I'm having trouble understanding what these unexpected issues might actually be... I guess that's why they're unexpected. In any event, a more careful test...
    http://files.datausa.com/imageshoppe...ME_DIMMING.mp4
    So, to summate what this test is showing... a 13KHZ (not even 30KHZ) dimmer, AT FULL DIM (5.5 stops under full brightness, BTW), running through shutter speeds from 1/60th down to 1/16,000 of a second. I'm using the aperture to keep the exposure at 50IRE as long as possible, then I have to let it trail off when I run out of stops. Why 50 IRE? So that the image doesn't clip and ruin any chance of detecting dimming. I then (right side of screen) normalize the levels to 100% so any pulsing or other effects will be exaggerated. As detailed or more than you can see on a scope while shooting. What I see is that you're fine until you hit 1/1000th of a second, then s*%t gets real and funky as the science project crashes and burns!
    My takeaway (others may differ) is that this 3 dollar US dimmer is allowing you to shoot at 240fps AT FULL DIM without any image issues. Again, AT FULL DIM (and WHY would you full dim a light when shooting high speed???).. when the LEDs are at full brightness you simply can't hit a shutter speed fast enough with the average cinema camera to cause issues unless you're at NASA AMES doing Phantom photography at thousands of frames per second. And if you're doing that, you should stay away from the 3 dollar dimmer.
    Regards,
    Jim Arthurs
  9. Collapse Details
    #29
    Senior Member
    Join Date
    Jul 2008
    Posts
    238
    Default
    Yes, sure, and I think that's fine, so long as it's understood by everyone.
    One upside to all this is that it's pretty easy to get DC converters which will do it without flicker, so frankly there may not be much need to do it with PWM unless you're in a very specific situation anyway. This is something else I could write about, maybe.
  10. Collapse Details
    #30
    Join Date
    Jul 2005
    Location
    New York, NY
    Posts
    2,180
    Default
    Phil I think I understand what you're saying but unless I'm wrong you seem to be suggesting that at 1/48th of a second it seems like worst case scenario you'd get up to a 1/625 variation in exposure, is that right? And on a whip pan where a blur travels 625 pixels you might see a variation of a 1 pixel offset between one line and another if the readout occurs during one of the 625 on/off cycles at 30khz? Am I thinking about this the right way?
    I'm having trouble imagining how it could manifest in a significant or even really observable artifact at all at such a high pwm frequency and low standard 1/48th sec shutter speed.
    Noah Yuan-Vogel
Posting Permissions
  • You may not post replies
  • You may not edit your posts
