Page 4 of 4 FirstFirst 1234
Results 31 to 37 of 37
  1. Collapse Details
    #31
    Senior Member
    Join Date
    Jan 2007
    Location
    Portland, OR
    Posts
    4,525
    Default
    considerations, considerations...
    hmm... all that said, it seems like the answer to my question from most participants was that "the whole set is redundant!" ;)
    But I'm still curious of my original question, which centered on "15, 21, 25" focal lengths. Is the 21 too redundant, or does it fill a nice hole? (S35 sensor)
  2. Collapse Details
    #32
    Senior Member Run&Gun's Avatar
    Join Date
    Jan 2014
    Location
    NC
    Posts
    3,640
    Default
    Quote Originally Posted by filmguy123 View Post
    My initial feelings would be, "unnecessary/redundant". But I felt that way about the 35 when I bought my set of CN-E's(it was just coming out and not widely available). But I had several shoots this summer that I needed it and have had some requests for it in rentals, so I added it about a month ago.
  3. Collapse Details
    #33
    Senior Member
    Join Date
    Mar 2012
    Location
    Australia
    Posts
    1,122
    Default
    Filmguy I think it's safe to say that only you can answer this question. 15mm, particularly for wide exteriors would come in very handy. Keep using the 25mm then if you feel like you're lacking add the 21mm! In non-narrative you can get away with way more without having that middle focal length. In narrative you may be up against a wall and the 21 gets you out of jail, or the director, if that's their style, may call for it specifically.
  4. Collapse Details
    #34
    Senior Member
    Join Date
    Mar 2012
    Location
    Australia
    Posts
    1,122
    Default
    PS I mean a literal wall where only the 21 will grant you the appropriate framing.
  5. Collapse Details
  6. Collapse Details
    #36
    Cinematography/Lighting Mod Ryan Patrick O'Hara's Avatar
    Join Date
    Jun 2006
    Location
    Los Angeles, CA
    Posts
    5,936
    Default
    A little off topic, but when I read documentary and events, I immediately thought zooms too. However, some documentaries aren't all spontaneous, and you can use prime sets and more traditional filmmaking techniques.
    Back to the original topic, I think the 21mm is great to have. Not only is it a great focal length, but if the 25mm isn't wide enough, the next lens down is a bridge too far. There is no way a cinematographer is going to be scratching his (or her!) head thinking "Oh man, this 25mm looks good, but I just need it wider...." and then finding the 15mm acceptable. No way. It's either 25mm or 15mm, and if you want a little wider than 25mm, you're out of luck.
    I say do it! I have an 18mm and 25mm in my lens kit, and I still bought my 21mm! It's a luxury in my situation but I love it. Would consider dropping the 18mm for it. Maybe.
    If cinematography wasn't infinite, I'm sure I would have found the end by now.
  7. Collapse Details
    #37
    Join Date
    Jun 2006
    Location
    Los Angeles, CA
    Posts
    5,936
    Default
    Quote Originally Posted by combatentropy View Post
    Picture is worth 1,000 words, or in this case, the amount I was spewing to make the same point. lol.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
