Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. Collapse Details
    #11
    Senior Member
    Join Date
    May 2011
    Posts
    287
    Default
    The Blackmagic Web Presenter should work, but is limited to 720p30 resolution (this is in part due to the fact that it uses a USB 2.0 connection to the computer). If you need to stream at a higher resolution than that you likely need a USB 3.0 capture device. Magewell USB Capture and AJA U-Tap are two pretty good USB 3.0 options that are oriented toward the professional video market in the $300 range. These can both capture up to 1080p60 video.
    There are also some less expensive capture devices geared toward the video game community, but I don't have much experience with these.
    Keep in mind that when streaming using a laptop, the capture device may not be the only limiting factor affecting the resolution and frame rate you can stream at. You also need a more powerful computer to handle live encoding of higher resolutions and frame rates. And this usually requires more network bandwidth for the stream as well.
  2. Collapse Details
    #12
    Senior Member
    Join Date
    Mar 2013
    Posts
    145
    Default
    Check out the new Blackmagic ATEM Mini. $295 and a ton of features...release is in Oct/Nov for pre-order right now...
    Michael
    Event, Sport & Personal Video espvideo.ca
  3. Collapse Details
    #13
    Senior Member jamedia.uk's Avatar
    Join Date
    Nov 2012
    Location
    Birmingham UK
    Posts
    577
    Default
    Quote Originally Posted by mrveronn View Post
    Only downside is no XLR input. The audio is 3.5mm jacks. All my mics (and the mixers) use XLR.
  4. Collapse Details
    #14
    Senior Member
    Join Date
    Feb 2013
    Location
    Sydney, Australia
    Posts
    659
    Default
    Quote Originally Posted by jredmond108 View Post
    Black Magic Design ATEM Television Studio HD, works well. priced right. https://www.bhphotovideo.com/c/produ...studio_hd.html
    +1 on that.
    Chris Young
  5. Collapse Details
    #15
    Senior Member
    Join Date
    Feb 2013
    Location
    Sydney, Australia
    Posts
    659
    Default
    Quote Originally Posted by jamedia.uk View Post
    I use Sony and Mackie audio mixers and going through level matching transformers to stereo mini jacks works okay. Not as secure as the good old XLRs but rarely an issue when all set up on a desk.
    Chris Young
  6. Collapse Details
    #16
    Senior Member
    Join Date
    May 2011
    Posts
    287
    Default
    If you have a camera with an XLR input you could feed the audio from your mixer into the camera and then use the embedded audio from that video source when it gets to the switcher.
    One added benefit of this approach is that it ensures that the audio signal will be in sync with the video. A lot of cameras can have a delay of a few frames on their video outputs, whereas analog audio paths rarely have any delay. So if you send the audio directly into the video switcher, it can often arrive a few frames ahead of the video signal. How much of an issue this is will depend on the camera used and how much output latency it has.
    1 out of 1 members found this post helpful.
  7. Collapse Details
    #17
    Join Date
    Nov 2012
    Location
    Birmingham UK
    Posts
    577
    Default
    Quote Originally Posted by davedv View Post
    All our camera have XLR inputs. So that is a good idea. Put the audio from the mixer into one XLR on the primary camera and it is all going to be in synch.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
