Page 31 of 31 FirstFirst ... 212728293031
Results 301 to 304 of 304
  1. Collapse Details
    Senior Member wschmid's Avatar
    Join Date
    Jan 2006
    Posts
    216
    Default
    Quote Originally Posted by Mitch Gross View Post
    4K Video Outputs:
    6G-SDI: 4K30p 10-bit 422
    HDMI 2.0: 4K60p 10-bit 422
    (These are the max throughput of these two, 6G-SDI & HDMI 2.0.)
    RAW data output:
    5.7K up to 30p
    4K up to 60p
    (Over 6G-SDI only. HDMI is a shared standard requiring a "handshake" between sender & receiver to function. Not compatible with RAW data.)
    No lock on the HDMI connector, but there is a door to the area where the port is located, and it is easy to ziptie to the door and/or the top handle to lock the cable in place.
    Will the raw Output be 10bit only? I think the Sony linear raw as offened by the FS7 is 12bit.
    Kind regards,
    Wolfgang
  2. Collapse Details
    Senior Member
    Join Date
    Jul 2007
    Location
    Toronto
    Posts
    6,827
    Default
    Quote Originally Posted by wschmid View Post
    Mitch has mentioned previously that EVA1 raw output will be 10-bit logarithmic raw which has a similar data range to Sony 12-bit linear raw.
  3. Collapse Details
    Join Date
    Jan 2006
    Posts
    216
    Default
    Weil that Would be Great.
    Kind regards,
    Wolfgang
  4. Collapse Details
    Join Date
    May 2017
    Location
    Urbana, IL
    Posts
    52
    Default
    New update on the EVA-1 regarding the ability to record 5.7K RAW from the camera. Some updates here: https://www.sportsvideo.org/2018/04/...mware-upgrade/
    Last edited by bfjewett; 04-04-2018 at 01:55 PM. Reason: already posted elsewhere.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
