Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 40
  1. Collapse Details
    #21
    Senior Member Thomas Smet's Avatar
    Join Date
    Jul 2005
    Location
    Colorado
    Posts
    2,190
    Default
    Quote Originally Posted by Cary Knoop View Post
    Increase the contrast or make other big changes, do you start to see stripes in the waveform? If so your footage might be handled like 8 bit.
    Sometimes it isn't as easy as that in a 32bit float environment. 32bit float will take a good looking shot in 8bits and typically keep it good looking by creating samples in between as needed. This can work in color sampling since we need subtle pixels differences. Fine detail doesn't need higher color depth. That is the opposite of image scaling where gradients can scale well and high detail looks horrible.
    So cranking a grade in a 32bit float will likely not show much difference in 8bit or 10bit as long as the 8bit had enough samples for the color.
    Only way to really tell if CS6 works with 10bit properly is to shoot a 8bit sample and 10bit sample of a subtle color gradient like a blue sky with the GH5 and see if there is a banding difference between the two. You have to shoot something that would typically fall apart in 8bit. Not always easy to do. This is why 10bit has been kind of a heavily debated subject for a long time. You have to be in just the right condition to make 8bit fall apart. 8bit does not always equal bad. It just doesn't have the overhead to handle difficult situations.
  2. Collapse Details
    #22
    Senior Member Cary Knoop's Avatar
    Join Date
    Jan 2017
    Location
    Newark CA, USA
    Posts
    1,059
    Default
    Quote Originally Posted by Thomas Smet View Post
    Frankly I have not encountered any of that 'auto dithering' in Premiere.
  3. Collapse Details
    #23
    Senior Member
    Join Date
    Mar 2010
    Posts
    2,513
    Default
    Adobe Premiere Pro CS6 is not an 8-bit video editor, it uses a 32-bit floating point internal working color space. Many of its bundled effects, however, are limited to 8 or 16-bit fixed point precision, and most are labelled as such in the user interface. IMO, Adobe should have mothballed these effects long ago, and replaced them all with 32-bit FP versions.
    https://forums.adobe.com/thread/825920
  4. Collapse Details
    #24
    Senior Member PaPa's Avatar
    Join Date
    Nov 2005
    Location
    Toronto, Ontario
    Posts
    7,676
    Default
    I don't have the camera or access to any footage. I found a 10-bit file that a user posted online that does not have any gradients in it for me to push around. I'll have to ask someone to upload something.
    http://www.imdb.com/name/nm2393063/
    Actor
    Musician
    Filmmaker
  5. Collapse Details
    #25
    Senior Member
    Join Date
    Jan 2011
    Posts
    251
    Default
    That's not quite how it works.
    Certain operations can create color values in the 32-bit space that fall between where the 8-bit or 10-bit values lie. In scaling, for example, that can happen, but only at the boundaries between colors. Otherwise, the video software is not creating in-between colors. If you've got big bands in 8 bits, you'll still have them after transformation to 32-bit floating point.
    It's difficult to measure color precision by looking at scopes, because the original encoding of the source file is confounded by the transformation your video software does when decoding the file. It gets transformed from YCbCr to RGB, and even the color difference channel scaling from 4:2:0 or 4:2:2 up to 4:4:4 can create intermediate values. In this example I take a set of gradients in uncompressed 10-bit and uncompressed 8-bit 4:2:2 YCbCr, read those in a video app, transform from RGB back to YCbCr and then expand the levels by 18.5x. From left to right, the scope is showing the channels in this order: Y, Cb, Cr. You can clearly see everything falling into nice 8-bit and 10-bit bands in all three channels, with the 10-bit file having four times the bands of the 8-bit file. If I count the number of bands in the scope, I can calculate the precision and see that it is indeed 8-bit or 10-bit in every channel. Note that the Y channel doesn't have the same precision as the Cb and Cr channels. Bonus points for anyone who knows why.
    You can right-click these images to open them in new tabs and then flip between them.
  6. Collapse Details
    #26
    Join Date
    Jul 2005
    Location
    Colorado
    Posts
    2,190
    Default
    Quote Originally Posted by balazer View Post
    That sure is how it works and the entire point why 32bit float exists. I don't care about scopes or synthetic images. I'm talking real world images here which 99% of people actually shoot and grade with. I said if the 8bit shot is good without any banding then 32bit float will tend to help the shot not get any extra banding by grading it very hard. It is only the material where the 8bits wasn't enough that the damage is already done.
    Thousands of people have noticed this when grading 8bit material in a 32bit float space and that is what led to the debate over is 10bit really worth it. Well the answer is it depends. If the shot works well in 8bit then it will be good. Yes there may be some loss or rounding error but we are talking about how a person can tell if a shot is 10bit or truncated to 8bits. My answer is it can be hard to tell sometimes.
  7. Collapse Details
    #27
    Join Date
    Jul 2005
    Location
    Colorado
    Posts
    2,190
    Default
    Quote Originally Posted by Lpowell View Post
    When the heck did I say CS6 was an 8bit editor? I said CS6 can work in a 32bit space when grading and therefore can sometimes be hard to tell if a shot is any worse in 8bits then it would be in 10bits.
    I was referring to the 10bit material to the GH5, which is the context of this discussion, which we know in the later versions of Premiere were incorrectly viewing 10bit as 8bit files. The question was how can we tell if the videos really are being treated as 10bit in CS6. At no point did I say CS6 was an 8bit editor.
  8. Collapse Details
    #28
    Senior Member
    Join Date
    Mar 2010
    Posts
    2,513
    Default
    That's not my understanding of the Adobe CC problems with GH4 10-bit 422 videos. The reports I've seen had nothing to do with misinterpreting the bit depth of the files, they were basic file handling and transport malfunctions. As far as I can tell, you're alone in conflating those issues with color depth support in an attempt to cast doubt on Premiere CS6 compatibility.
  9. Collapse Details
    #29
    Senior Member
    Join Date
    Jan 2011
    Posts
    251
    Default
    If your point is that 8-bit is good enough a lot of the time, I'm in complete agreement. If an image looks good, it is good. I make images for people, not for signal analyzers. The fact that people aren't even sure if a file was processed with 8-bit or 10-bit precision illustrates some of the folly in aiming for 10 bits. That's not to say that working 32-bit floating point solves all precision problems. If you shoot in 8 bits, color correct in 32-bit floating point, and deliver in 8 bits, it's possible to get banding in the output that's noticeably worse than in the input. It depends on the specific image and how it is manipulated. A slight increase in contrast in the wrong place can be enough to make two neighboring bands two code values apart instead of one code value apart. In an SDR display color space, most of the 8-bit code values are close to a just noticeable difference apart from their neighbors. 2 x JND is quite noticeable.
    And if you're shooting in a high dynamic range camera log space such as S-Log2 or Canon Log 2, it's completely different. Neighboring code values in these spaces are different colors by a lot more than a JND.
    That's the last I have to say about the subject in this thread.
  10. Collapse Details
    #30
    Join Date
    Jul 2005
    Location
    Colorado
    Posts
    2,190
    Default
    Who the heck is casting doubt on CS6 compatibility? I think you need too go back and read the context of the discussion going on. A person asked why is it his 10bit GH5 files work fine in CS6 while newer versions had issues. I said I don't know but maybe it is similar to a previous version of CC where the 10bit files did work but based on what Cinema5D found in their infamous article the 10bit and 8bit files looked like they had the same color depth. I never indicated that CS6 doesn't work and clearly it does if it does for this particular person. Somebody asked for help and since nobody else chimed in I provided a potential reason why the files do work in CS6. Hard for me to know for sure since I no longer use older versions of Premiere. Perhaps the 10bit files are working 100% as 10bit. I never said they don't, just that it may be hard to see if they do or do not on certain types of footage.
    All I pointed out was that sometimes it is hard to tell the difference between some 8bit files and 10bit files even if they are handled correctly in the software so a simple grading test may or may not provide a definitive answer to the persons question. I didn't realize pointing out that sometimes 8bit can be hard to distinguish from 10bit would touch such a nerve on here today.
    Perhaps you can provide your own explanation as to why the 10bit files seem to work perfectly fine in CS6 while newer versions had an issue. I would love to hear it so I'm not the only one stabbing in the dark trying to help another user.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
