Thread: Defect on Lens?
Page 1 of 4 1234 LastLast
Results 1 to 10 of 32
  1. Collapse Details
    Defect on Lens?
    #1
    Junior Member Cinephile's Avatar
    Join Date
    Apr 2005
    Posts
    21
    Default
    So I just got my DVX200 and I'm testing it out and It seems that my lens is defected. There are two green spots that won't go away no matter where I turn my camera! I tried wiping it with a professional lens pen and brush but the spots won't go away. I don't know if its the lens or the actual sensors that are defected but the spots always are at the same exact spot! Anyone here run into this problem? Could it be just a lens flare?
  2. Collapse Details
    #2
    Senior Member JPNola's Avatar
    Join Date
    Nov 2014
    Location
    New Orleans USA
    Posts
    1,238
    Default
    Bummer.
    If it is always in the same spot it is not likely a lens flare. I would attempt a black balance, just in case that might clear up the issue.
    To black balance the camera, cover the lens, then press and HOLD the white balance button until you see "BB Set OK". If you cover the lens at the spot goes away, that to me indicates an issue with the lens and not with the sensor.
    What I see in the examples looks more like an optical defect than anything that a Black balance will cure.
    Big sources matter.
  3. Collapse Details
    #3
    Senior Member JRJphoto's Avatar
    Join Date
    Dec 2007
    Location
    Texas, USA
    Posts
    666
    Default
    ...that looks like flare. Any video examples?
    Jason R. Johnston
    Cinematographer Videographer Photographer
    web: jasonrjohnston.com
    instagram: jasonrjohnston
  4. Collapse Details
    #4
    Senior Member Design Media Consultants's Avatar
    Join Date
    Mar 2016
    Location
    South Florida
    Posts
    297
    Default
    Quote Originally Posted by JPNola View Post
    Bummer.
    You do not have to cover the lens to black balance the DVX200.
  5. Collapse Details
    #5
    Join Date
    Mar 2016
    Location
    South Florida
    Posts
    297
    Default
    If you are shooting under various light conditions and locations, I do not think it would be a lens flare. Are you shooting in manual or auto? Try auto and shoot in as many locations and different light conditions as possible. Show us a short video clip. It does not appear to be a lens defect. Can't tell much from the photo.
    The DVX is a complex camera and it could be some setting that is causing it, or even a corruption in the software. This might be a question for Barry Green. If it is something internal on the chip, etc., Barry would know.
  6. Collapse Details
    #6
    Join Date
    Apr 2005
    Posts
    21
    Default
    So i've been shooting and it seems that the green spot does move around the frame and does not stay at the same spot. It looks like normal lens flare to me now when I actually move the camera. Let me know if this is normal for you guys and gals too.
    Here's the video: https://www.youtube.com/watch?v=sl4l...ature=youtu.be
  7. Collapse Details
    #7
    Senior Member
    Join Date
    Mar 2009
    Location
    Augusta, Georgia Area
    Posts
    538
    Default
    You have a very bright light in the image you provided.
    Try turning off that light, and light the subject from the front with a softer light and see if the green spots go away.
    This looks like a lens flare, not a lens defect, to me.
    Respectfully,
    Dan Keaton
    Convergent Design
  8. Collapse Details
    #8
    Senior Member
    Join Date
    Feb 2016
    Location
    Fort Collins, CO
    Posts
    214
    Default
    Quote Originally Posted by Cinephile View Post
    Lens flare. If you have a lens filter installed, try the same shot without it.
  9. Collapse Details
    #9
    Junior Member
    Join Date
    Feb 2016
    Location
    Derby
    Posts
    21
    Default
    Lens flare - not a defect. You're almost shooting straight into a very bright light. If you need to shoot with this sort of light maybe move the camera further away and to one side and then use a flag to control how the light hits the lens. http://nofilmschool.com/2014/02/the-...trast-to-scene
  10. Collapse Details
    #10
    Join Date
    Dec 2007
    Location
    Texas, USA
    Posts
    666
    Default
    April fools joke?
    Jason R. Johnston
Posting Permissions
  • You may not post replies
  • You may not edit your posts
