Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
  1. Collapse Details
    #21
    Join Date
    Apr 2013
    Location
    Vienna
    Posts
    73
    Default
    @BONLEV
    Larry give you some excellent hints. But there is another good way to overcome the bad autofocus system. I use a cam remote from DigiPin (PanRe), with this remote you can program 3 focusplanes. I use it often in dance halls. 1st is front 2nd is middle and 3rd is far. So I can quickly change the focusplane by pressing a button on the remote. This works great! No focus hunting at all, even in low lit environment. And yes I'm also using an external Monitor. I's much better because I'm always have a waveform monitor in the right lower corner on to see the correct aperture setting...
    Good luck
    Jack
    1 out of 1 members found this post helpful.
  2. Collapse Details
    #22
    Senior Member
    Join Date
    Feb 2005
    Location
    Washington, the state.
    Posts
    3,624
    Default
    Excaliber,
    Could you give a link to the specific DigiPin product.
    I use this no longer in production Manfrotto 521PFI for similar situations. You can set limits on the focus wheel, so only two setting can be saved, but it does work quite well.
    https://www.adorama.com/bg521pfi.html?discontinued=t
    Grant
  3. Collapse Details
    #23
    Join Date
    Apr 2013
    Location
    Vienna
    Posts
    73
    Default
    Hi Grant,
    please here the DigiPin website:
    http://digipin13.hr/en/
    But please note that there is a new Panasonic remote coming out in a month. Please ask them directly via e-mail:
    dario@digipin13.hr
    His Name is Dario.
    Mine has 3 focus memories, illuminated, so you see your selection.
    [IMG]NÍ Cup 2018 620k.[/IMG]
    If you need more info, you can contact me by mail
    Jack
  4. Collapse Details
    #24
    Join Date
    Apr 2013
    Location
    Vienna
    Posts
    73
    Default
Posting Permissions
  • You may not post replies
  • You may not edit your posts
