Results 1 to 3 of 3
  1. Collapse Details
    Internal battery charge question
    #1
    Senior Member
    Join Date
    Dec 2008
    Location
    USA
    Posts
    1,867
    Default
    Regarding the internal camera battery that saves date, settings etc and eventually needs charging to retain info if it not used for a long period of time:
    On these Panasonic cameras (such as AG HMC 150) if you attach the battery and leave the camera powered off will the internal battery charge?
    Or must you plug in AC power cable and leave it powered off?
  2. Collapse Details
    #2
    Junior Member
    Join Date
    Mar 2017
    Location
    Toronto / GTA
    Posts
    27
    Default
    The manual says the 150 needs to off, and plugged into the charger for at least 4 hours to charge the internal battery.
    I tried using just the battery, but it didn't work. It is on the charger now. (Hoping the battery is not to far gone)
  3. Collapse Details
    #3
    Senior Member
    Join Date
    Dec 2008
    Location
    USA
    Posts
    1,867
    Default
    Thank you. That seems to be correct. I did it with my Panasonic cameras and also one Sony.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
