Results 1 to 3 of 3
  1. Collapse Details
    FLUO Appeared on Display
    #1
    Senior Member Ron Rodenmeyer's Avatar
    Join Date
    Dec 2005
    Location
    Jackson, MS
    Posts
    336
    Default
    While shooting this week with my HMC-150, the word "FLUO." appeared in the upper right corner of my screen at some point. I can't figure out what setting has been engaged. The Matrix I'm using is not using Fluo. Has anyone seen this before?
    Note that Pana recently did some repair work on the camera after it started doing things like zooming on its own or going immediately into record mode when turned on.
    Thanks,
    Ron
  2. Collapse Details
    #2
    Default
    It's the name of the scene file. It doesn't necessarily reflect the contents of the scene file. If you rotate the scene file dial, you'll see different names appear up there (like b.press, cine-D, cine-V, fluo, and spark).
  3. Collapse Details
    #3
    Join Date
    Dec 2005
    Location
    Jackson, MS
    Posts
    336
    Default
    Thanks, Barry! I've had it on Cine-D for so long, I didnt even realize I had bumped the wheel and changed it. I just knew it looked different in the viewfinder.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
