Page 1 of 2 12 LastLast
Results 1 to 10 of 19
  1. Collapse Details
    Dropped and broke HMC-40 today, bummed
    #1
    Senior Member
    Join Date
    Sep 2008
    Location
    Virginia Beach
    Posts
    341
    Default
    Well, I dropped and broke the HMC-40 today, just a stupid accident. It was super low hour and perfect condition until this. The battery tangs in the camera housing broke out looks fixable, but very difficult.
    So now a quick search shows the HMC-40 is discontinued an there is no compact replacement. The 90 looks to be a 40 but full size, is that right?
    So, what do I replace the 40 with that has a more compact form factor?
    AG-HMC150, HMC-40, Sony Vegas Pro 8.0c, Sony PCM D-50, JVC GR HD-1
  2. Collapse Details
    #2
    Moderator Alex H.'s Avatar
    Join Date
    Sep 2008
    Location
    Knoxville, TN
    Posts
    8,226
    Default
    The AC-90A is only slightly larger than the HMC-40. Not enough difference to be of concern.
    It's the HMC-80 that's a full(er)-sized, shoulder-mount version of the HMC-40
    Knoxville-based location sound mixer.
    Instagram @sonolocus
  3. Collapse Details
    #3
    Senior Member
    Join Date
    Sep 2008
    Location
    Virginia Beach
    Posts
    341
    Default
    So is the 130 and 160 bigger than the 90?
  4. Collapse Details
    #4
    Join Date
    Sep 2008
    Location
    Knoxville, TN
    Posts
    8,226
    Default
    Quote Originally Posted by jeff9329 View Post
    A bit, yes. The AC130a and AC160a both measure 7"x7.69"x17.25" and weigh 5.3lb without battery. The AC90a measures 6.3x7.68x13.78, weighing 3.9lb.
  5. Collapse Details
    #5
    Senior Member
    Join Date
    Sep 2008
    Location
    Virginia Beach
    Posts
    341
    Default
    AC130 is: Dimensions (WxHxD) 7 x 7.69 x 17.25" (18 x 19.5 x 43.8 cm) excluding protrusions
    AC90 is: Dimensions (WxHxD) 6.30 x 7.68 x 13.78" (16.0 x 19.5 x 35.0 cm) excluding protrusions
    HMC40 is: Dimensions (WxHxD) 5.3 x 5.3 x 11.9" (13.6 x 13.5 x 30.4cm)
    Cut and paste from the B&H website
  6. Collapse Details
    #6
    Senior Member
    Join Date
    Sep 2008
    Location
    Virginia Beach
    Posts
    341
    Default
    I guess I am going to have to explore other manufacturers to see who has a smaller size pro camera. Could just get a 130 while the $400 rebate is in effect, but I enjoy having one more compact camera in the kit.
  7. Collapse Details
    #7
    Join Date
    Sep 2008
    Location
    Knoxville, TN
    Posts
    8,226
    Default
    You pretty much reiterated my points made above: the AC-90a is only slightly larger than the HMC-40, and the AC-130/160 are considerably larger than both the AC-90a and the HMC-40. NONE of these is considered a full-sized camera. They are all compact camcorders, and the difference between the HMC-40 and the AC-90a is pretty marginal once you get your hands on them.
    If you want very small, look at the Canon XA10/20/30. The downside there, in my opinion, is that you'd be shooting with a Canon prosumer camcorder. I have never been a big fan of their prosumer camcorders, going all the way back to the GL-1. You'll also lose much of the tactile control features the AC-90a would offer, especially with control rings behind the lens.
  8. Collapse Details
    #8
    Senior Member
    Join Date
    Sep 2008
    Location
    Virginia Beach
    Posts
    341
    Default
    Is the Sony PXW-X70 a small unit on par with the HMC-40?
  9. Collapse Details
    #9
    Senior Member
    Join Date
    Mar 2015
    Location
    Philippines
    Posts
    128
    Default
    If you want something smaller than the AC90, then you might want to consider the HC-X1000.
    Panasonic HC-X1000 | GoPro Hero4 Black Edition | 3770K | GTX760
  10. Collapse Details
    #10
    Senior Member
    Join Date
    Sep 2008
    Location
    Virginia Beach
    Posts
    341
    Default
    That is a really interesting camera. Except for a lot of hi-res formats that I wont use, its very cool.
    HCX1000 Dimensions (WxHxD) 6.3 x 6.7 x 12.4" / 160.0 x 170.0 x 315.0 mm
    PXW-X70 5 1/4 x 7 1/8 x 11 3/8 inches (with lens hood, eyecup, and XLR handle unit) (excluding grip belt and including projecting parts)
    A quick look at the HCX-1000 reviews say its terrible in indoor light. I think that's out.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
