Page 206 of 222 FirstFirst ... 106156196202203204205206207208209210216 ... LastLast
Results 2,051 to 2,060 of 2217
  1. Collapse Details
    Senior Member Thomas Smet's Avatar
    Join Date
    Jul 2005
    Location
    Colorado
    Posts
    1,894
    Default
    Quote Originally Posted by stoneinapond View Post
    Are you referring to the process of optimizing media in FCP X, or are you using QuickTime for conversion in some other fashion?
    Either but for the most part optimized.
  2. Collapse Details
    Senior Member stoneinapond's Avatar
    Join Date
    Jul 2009
    Posts
    2,216
    Default
    Quote Originally Posted by Thomas Smet View Post
    Are able to play 10-bit files in QuickTime?
  3. Collapse Details
    Senior Member
    Join Date
    Jan 2004
    Location
    Gunnison, CO
    Posts
    303
    Default
    FWIW, I use windows PremierPro 2017 and have been using AME to transcode the internally recorded MOV files to DnX HQ & HQX with no issues. On my computer PP won't play the MOV files but has no issues with the DnX files.
  4. Collapse Details
    Join Date
    Jul 2005
    Location
    Colorado
    Posts
    1,894
    Default
    The 10bit native files from the GH5 do play in FCPX but not great. That is likely due to my system which is a 2012 iMac. Still a killer machine with ProRes material but not so great with native 4k material. I know others have had better playback results in FCPX with native 10bit files with newer machines.
  5. Collapse Details
    Senior Member
    Join Date
    Feb 2009
    Posts
    167
    Default
    Quote Originally Posted by Batutta View Post
    Retarded. Im able to use my Vlog Gh5 10 bit with my davinci resolve. I wish they would stop blaming softwares and blame operating systems instead.
  6. Collapse Details
    Senior Member
    Join Date
    Jul 2007
    Location
    Toronto
    Posts
    6,234
    Default
    Hmmm... GH5 internal recording is BETTER than GH5 external recording ???
  7. Collapse Details
    Senior Member
    Join Date
    Jan 2004
    Location
    Gunnison, CO
    Posts
    303
    Default
    What do you think? I've been looking at the Ninja Inferno for the external recording, monitoring assistance (false color), and the larger/brighter screen for my declining eyesight and outdoor use. But if the recording is better internal (I'm skeptical - surely something else is going on . . .), I'll just find a monitor.
  8. Collapse Details
    Join Date
    Jul 2005
    Location
    Colorado
    Posts
    1,894
    Default
    Quote Originally Posted by Steve Ogden View Post
    I will give my two cents worth of advice on this.
    A monitor isn't always just a monitor and there is a wide range of quality differences between monitors out there. The Atomos monitors are not just great external recorders but also rank up there in terms of monitor quality. 1500nit brightness and 10bit FRC color are some pretty significant features that make the Atomos monitors stand out above most of the low cost monitors out there. The HDR support is also very welcome along with all the scopes and tools. False Color is one of the best tools to use for exposure and the GH5 doesn't have that. So yes there are still plenty of reason to get a Flame/Inferno. There are professional monitors only solutions out there that cost as much as the Flame so really you are getting a great monitor with the recording thrown in for free.
    A couple other things to think about. That above test is plagued by the same issue as every other internal vs external test out there. It doesn't actually test what stresses an internal encoder. Formats like h264 tend to fall apart with heavy random motion with lots of detail. h264 works based on motion prediction. A car driving across the screen is easy to predict. Random tree branches blowing in heavy wind or surf in the ocean are not so easy to predict motion. Every single internal vs external test out there is flawed because they lock down the camera and either shoot a still life scene or a single low detail subject with very little movement. If waving a head in front of a green screen broke h264 that much nobody would ever use it as a format. My point is that yes eventually external recording will be worth it. You may not see it on every shoot but eventually you will shoot something that does benefit from the higher quality recording. So it is never a useless tool to have. A format like ProRes422 HQ is about consistency and knowing every shot no matter how simple or complex will look the same. Internal 10bit might get you 90% of the quality which is amazing but it is how important that last 10% is where some of us still prefer external recording.
    Time is the last point I will make. If you don't have a system fast enough for smooth 4k editing or that can handle the 4k 10bit files then recording external vs converting in post can save you a lot of time. Some of us always edit with an optimized or converted version so recording external saves us a huge amount of time and effort where we can start right away cutting away at our material. ProRes works well from even an older laptop which means you are not as much a slave to bleeding edge computers to get your work done. Starting with ProRes also means your final renders and exports will be faster. How much so depends on the complexity of the effects you use and the length of the exports. ProRes needs faster and larger drives but that stuff is cheap now and considerably cheaper than buying a new $3,000 computer to keep ahead of the new formats. Some people also can't even play the GH5 10bit files right now. Not an issue with ProRes. Any new camera that comes out I can record the same format I am used to using. My workflow never has to change because of some new odd camera format.
    1 out of 1 members found this post helpful.
  9. Collapse Details
    Senior Member Batutta's Avatar
    Join Date
    Mar 2005
    Location
    Planet 10
    Posts
    7,268
    Default
    Every distributor I deliver final files to requests ProRes 422 HQ, so it's pretty much an industry standard at this point.
    "Money doesn't make films...You just do it and take the initiative." - Werner Herzog
  10. Collapse Details
    Senior Member Cary Knoop's Avatar
    Join Date
    Jan 2017
    Location
    Newark CA, USA
    Posts
    753
    Default
    I will ignore the endless bashing of H.264, with similar bitrates H.264 is just as good as any other codec, and H.264 can encode intra-frame only as well without all those alleged 'bad' motion issues. H.264 can even encode lossless if necessary.
    That is simply not true, whatever codec you use in order to re-encode you need to decode it first, decoding of inter-frame H.264 will not be significantly different than decoding ProRes as long as the the video is rendered sequentially. The slowness comes only when you move the play head to a particular place, then the NLE needs to calculate the current frame if it is not an I-frame.
    0 out of 2 members found this post helpful.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
