Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 38
  1. Collapse Details
    #21
    Senior Member
    Join Date
    Mar 2013
    Location
    Vancouver
    Posts
    122
    Default
    Or you could just buy the trigger cable pre-made https://mediablackout.net/products/w...t=12616828102#
    It’s the same as the Arri/Sony F65 cable version.
    Ed Araquel - Photographer, SMPSP
    http://edaraquel.com
    Sony F65, 2 - A7RIII, A6500 and a mixed bag of Nikon, E mount, and PL mount lenses
    Instagram: @edaphotographer
    1 out of 1 members found this post helpful.
  2. Collapse Details
    #22
    Senior Member rbirnbaum's Avatar
    Join Date
    Aug 2016
    Location
    NYC
    Posts
    264
    Default
    Ed, do you know if that will trigger SDI record? I know that nothing lights up unless the right unit is docked. Sony built in this safety feature so that the camera doesn't record unless everything checks out as working. I assume it's for insurance purposes. Don't want the camera not recording in a multimillion $ production.
    Does anyone have one of these triggers they can test out, see if the camera will fire up the SDI record flag?
  3. Collapse Details
    #23
    Senior Member
    Join Date
    Feb 2009
    Posts
    6,643
    Default
    Fun story: that function was added to the F35 after the Superman Returns mishap with the Genesis (precursor to the F35). On the Genesis the menus on the camera head and the recorder completely didn't interact and the communication was minimal. Even with the F35 and the F65 the cameras and the recorders were built in separate factories. Superman Returns was one of the very first productions to shoot on Geneis. At lunch on the first day they went to check some footage and discovered that they had been recording bars all morning. So ony decided to improve the communication between camera & recorder with the F35.
    Mitch Gross
    Cinema Product Manager
    Panasonic System Solutions Company
  4. Collapse Details
    #24
    Senior Member
    Join Date
    Aug 2014
    Posts
    285
    Default
    Quote Originally Posted by rbirnbaum View Post
    IIRC I tested this out with the Odyssey back when I had a F35. I ordered the connector online and built a cable myself. It is actually fairly easy to test as all you have to do to trigger the F35 is to short the remote pin with the ground pin (I may be remembering that wrong, there were some wiring diagrams posted here or maybe in the user manual so please double check before trying testing anything). It would trigger the tally lights and quiet operation of the fans, there maybe some settings in the F35 that need to be set to allow the unit to trigger without having a recorder docked.
    The issues I had were that one the trigger has to be a toggle switch and not a momentary switch, the trigger only is enable while the wires are shorted and that the F35 does apparently send trigger signals over SDI but the odyssey was not able to detect them. Apparently it was intented for allowing the F35 to trigger the SRW-1 when it was not docked to the camera and uses a proprietary sdi signal.
    Since the odyssey has the ability to output a voltage over its remote connection when recording is enabled and that is used to light up the LED on the trigger cable you can purchase for it I was going to attempt to use that current to trigger the F35. My thinking was when the odyssey was recording it would output a current that I would pass to a relay that would then be used to trigger the F35. I was never able to get this to work though, it appears that the current was just too small and I wasn't able to get a hold of a relay sensitive enough to activate.
    I do recall also trying to trigger both the Odyssey and the F35 at the same time with a cable that basically split off to both but it didn't work. I could trigger the F35 but the Odyssey wouldn't trigger, I believe the the current coming from the F35 was causing issues, the fact that the trigger needed to be a toggle might have been an issue as well but I don't recall now.
    I am sure this is something that can be done, the Odyssey does output a voltage when recording is active to light up an LED on its trigger cable and that voltage could be detected and used to trigger the F35 but I never went that far. Please test out for your selves though, tt has been a while and I could be mistaken but that is my recollection of how my testing went.
  5. Collapse Details
    #25
    Senior Member
    Join Date
    Aug 2014
    Posts
    285
    Default
    Another thing that I found was the F35 could be triggered using a momentary switch only with a recorder docked and had to be a toggle switch without. Something to consider when looking for a trigger.
  6. Collapse Details
    #26
    Join Date
    Aug 2016
    Location
    NYC
    Posts
    264
    Default
    Sounds doable with toggle switch. Not opposed to it. Maybe something very old school. Rerouting the wiring and maybe popping it through the LDS port which no one uses. Right under the lens. Easy location. If it gave tally record light that would be fantastic.
    I have triggered external recorders via SDI using a docked recorder. All the Odyssey, PIXE5 and BM VA triggered via the IF box or Monitor outs. So something is coming out of the camera. Question is, if there is no docked recorder and we use the toggle switch, will it get the SDI flag out? Should be an easy test. Couple cables, one of these switches... I’ll give it a shot when I have time.
  7. Collapse Details
    #27
    Senior Member James0b57's Avatar
    Join Date
    Dec 2008
    Posts
    3,899
    Default
    Ribirnbaum,
    Very interested in you discoveries. I am setting up a leica r mount for one of my f35ís, and plan to use it for a project. Being able to trigger fans/recorder with the same switch/buttone would be a godsend.
    And if i head to NYC, iíll bring the R35 (Leica F35) with me.
  8. Collapse Details
    #28
    Join Date
    Jun 2016
    Location
    Melbourne, Australia
    Posts
    49
    Default
    This is an interesting discussion! Thanks to everyone for their input.
    I've been attempting to trigger a record SDI flag from the F23 to my SR-R1 by simply shorting that 24v trigger pin to ground, and whilst it does turn the tally light on, there doesn't seem to be much else that happens.
    With the settings in camera set to "recorder" the tally comes on and SR-R1 confirms that an acceptable SDI trigger source is connected, but no actual recording starts.
    So perhaps I'm doing something wrong or the F23 still expects a docked recorder to actually make things happen, in line with what Mitch discussed.
    Haven't tried with a proper run/stop but I wouldn't think it would work any differently to just holding the trigger pin to GND.
  9. Collapse Details
    #29
    Join Date
    Aug 2016
    Location
    NYC
    Posts
    264
    Default
    Quote Originally Posted by helweg View Post
    Going to pick up this thread and try everything people are saying. We need some images to clarify what we are talking about. Seems like a lot of talk about pins... I also remember vidovation mentioning that there is a push pin on the dock ports of the cameras that tell the camera that there is a recorder docked. Maybe this pin plus the toggle switch may get it working.
    Let's see.
    Any other tests on your end, please share progress.
  10. Collapse Details
    #30
    Senior Member
    Join Date
    Aug 2014
    Posts
    285
    Default
    Here is the wiring diagram for the remote port on the F35 (Page 142 in the manual). To trigger recorder you need to short the GND pin with the Remote pin. As long as those pins remain shorted the camera will be in record mode with tally's, etc... If I recall correctly there is a setting in the Maintenance menu to get triggering to work. I looked at the manual and I believe it is the REC TRIGGER setting which can be set to SWITCH or RECORDER, I don't recall which one is correct option though.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
