Page 2 of 7 FirstFirst 123456 ... LastLast
Results 11 to 20 of 64
  1. Collapse Details
    #11
    Senior Member
    Join Date
    May 2014
    Posts
    132
    Default
    So here is a quick little test comparison between S-Log and PanaLog.
    Recorded on Hyperdeck / Uncompressed / Ungraded
    It was compressed to .h264 for vimeo. Vimeo did some weird compression in the first seconds. But you can see the difference between S-Log and PanaLog.
    1st clip is always S-Log
    2nd clip is always PanaLog
    https://vimeo.com/131378395
  2. Collapse Details
    #12
    Join Date
    Jun 2014
    Location
    Vienna, Europe
    Posts
    63
    Default
    What is your opinion about the two?
  3. Collapse Details
    #13
    Senior Member
    Join Date
    May 2014
    Posts
    132
    Default
    Well, I'd definitely say that the S-Log is more flat and would need more grading and with the PanaLog you have an almost "graded" look, with more details and contrast. I will do some more testing and will put up a graded version of both, to see any differences. It could be, that PanaLog already looks a little bit "graded", in order to have a quicker grading process in the end. Not sure about that.
  4. Collapse Details
    #14
    Senior Member
    Join Date
    May 2014
    Posts
    132
    Default
    I have graded both files with the exact same procedure in DaVinci. I saved the grade of the S-Log and added the exact same correction to the PanaLog. I used a Kodak Visioncolor Impulz Lut as a Film Negative Emulation in Cineon Log as a base node. I then graded. As a final node I applied a Kodak Film Print Emulation.
    It looks like the PanaLog gives an overall boost in the highlights and midtones. You can see the difference on the right hand corner in the trees. The highlights in the trees are blown out in the PanaLog. The overall image also seems more contoured.
    The "shining" added in the PanaLog is nice, but am not sure whether I would use S-Log or PanaLog for a feature.
    1st still is S-Log
    2nd still is PanaLog
    Attached Images Attached Images
    1 out of 1 members found this post helpful.
  5. Collapse Details
    #15
    Senior Member JMtheDP's Avatar
    Join Date
    Feb 2013
    Location
    United Kingdom
    Posts
    1,415
    Default
    I believe Panalog was designed to use as much of the available recording medium as possible, where Sony chose to leave some wiggle room. I'm not sure why.
    Panalog was pretty much designed to be used in conjunction with a GDP or something similar.
    James Martin, UK-based DoP
    www.jamesmartindop.com
    Sony F65, ARRI/Zeiss Master Primes, ARRI Alura Zooms
    Formerly: F900, F35, Zeiss Standard Speeds, Illumina S35s...
  6. Collapse Details
    #16
    Senior Member
    Join Date
    Feb 2015
    Posts
    202
    Default
    I much prefer the highlights in S-log. Don't see any appeal in Panalog.
  7. Collapse Details
    #17
    Senior Member Mike Krumlauf's Avatar
    Join Date
    Apr 2006
    Location
    OG from Chicago. Currently in Denver, CO
    Posts
    1,251
    Default
    Were you ever able to extract the PanaLog from the camera or replicate it in CVP file editor? I'm trying to find it to run my own tests on my F23. I reached out to my friends at Panavision and have yet to hear back.
    Mike Krumlauf
    JSAV A/V Technician
    Denver Tech Center
    GEAR
    _________________________________
    Panavised Sony F23 / SRW1-SRPC1 Recorder
    Fujinon XA16x8A HD Zoom Lens
    Chrosziel MB 450-01
    Apple Mac Pro 8 Core 2008 W/ AJA Kona 3 Dual-Link 4:4:4 Capture Card
    Apple Macbook Pro 15-inch 2007
    Final Cut Studio 3
  8. Collapse Details
    #18
    Senior Member rbirnbaum's Avatar
    Join Date
    Aug 2016
    Location
    NYC
    Posts
    268
    Default
    Keep us posted Mike
  9. Collapse Details
    #19
    Join Date
    Apr 2006
    Location
    Posts
    1,251
    Default
    Quote Originally Posted by rbirnbaum View Post
    Keep us posted Mike
    I was able to get PanaLog from another DVXuser and i'm doing some private tests to get a workflow down and am really amazed by the results. Once I have some time to shoot something solid I will share a video with you guys.
    Mike Krumlauf
    JSAV A/V Technician
    Denver Tech Center
    GEAR
    Chrosziel MB 450-01
    Final Cut Studio 3
  10. Collapse Details
    #20
    Join Date
    Aug 2016
    Location
    NYC
    Posts
    268
    Default
    Quote Originally Posted by Mike Krumlauf View Post
    Share when you can Mike. Curious as to what you find out.
    How are you using the GDP processor?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
