Page 2 of 10 FirstFirst 123456 ... LastLast
Results 11 to 20 of 95
  1. Collapse Details
    #11
    Senior Member
    Join Date
    Dec 2011
    Location
    Florida
    Posts
    2,359
    Default
    I apolgize if I am misunderstanding your post, but you have described exactly what Center Scan is all about. It's like the DX and FX modes on a Nikon full-frame SLR.
    Read my article. And the center cut comes with no loss of sharpness or loss of light. It's a great feature on the F55 and I use it all the time. Turns my RED 300mm into a 600mm f/2.9. Makes my Zeiss 15.5-45mm a 31-90 at the touch of a button. Great for run and gun.
  2. Collapse Details
    #12
    Senior Member Grug's Avatar
    Join Date
    Apr 2007
    Location
    Melbourne, Australia
    Posts
    3,815
    Default
    Centre Crop is a great feature. I use All Files to make it a two-button-press operation (which is moderately painless). Having to wait for the whole camera to reboot is a pain in the proverbial though.
    Best uses for it are for super-close focus work, and for aliasing-free HFR work. Also great when you're short on time for a close-up, and don't have time to change lens, change camera position and re-find focus marks.
  3. Collapse Details
    #13
    Senior Member
    Join Date
    Oct 2009
    Location
    Nashville, TN
    Posts
    2,022
    Default
    Quote Originally Posted by Doug Jensen View Post
    I'm not sure if this was in response to me. If it was, then - I guess my uncertainty is the implementation. For instance, I'm not sure whether this was intended just for high frame rate, or also as a mode for regular speed shooting, and then whether it would be it's own mode, or whether it would be available instantaneously. The PXW-FS7 certainly does reboots for a lot of mode changes, so I wasn't counting on a implementation that would be fast and easy with not rebooting. If you're confident it won't, that's certainly excellent news.
    Of course there wouldn't be a loss in light for using the center crop, but my understanding is that at regular frame rates (up to 60p) the camera's downscaling takes advantage of the entire 4k sensor to make the 1080p image naturally sharper. Given that it has 11.6 megapixels and a 1080p only camera like the F3 only has something like 3.36 megapixels, I'm not surprised when the fine detail on the FS7's 1080p is naturally sharper than the F3 even when both are recorded to 1080p. My thinking is that by using a center crop, the camera would lose this advantage (at least to an extent) and might not be quite as sharp as when using the full sensor. Mind you, I think there are numerous situations where this trade-off would absolutely be worth it, so I'm certainly not complaining.
    As for high speed, again, I suspect it would come down to implementation, but since the high speed frame rates don't use every photosite anyway, using a center crop in high speed might very well be just as sharp as a full scan - for that mode.
    Doug - I suspect you're better informed on this issue than I am, but hopefully that clarifies what I meant to suggest.
    James Houk, DoP
    Sony F35
    Sony PXW-FS7
    Arri Ultra Prime Set
    www.binarydreams.com
  4. Collapse Details
    #14
    Senior Member
    Join Date
    Nov 2008
    Location
    New York City
    Posts
    749
    Default
    Damn.. They really are giving the FS7 all the features of the F5/55.
    You guys will love it, fantastic feature for when there isnt time to change lenses or you just need to really reach out to 400mm +
    http://www.billthomasphoto.com/
    Sony F5 / F3/ EX-1 / Nikon D800 / BMPCC / Atomos Samurai / Zeiss & Nikon lenses
  5. Collapse Details
    #15
    Senior Member
    Join Date
    Oct 2008
    Location
    New York
    Posts
    654
    Default
    Quote Originally Posted by Viddovation View Post
    Resolution and sharpness are two different things.
    1 out of 1 members found this post helpful.
  6. Collapse Details
    #16
    Senior Member
    Join Date
    Oct 2009
    Location
    Nashville, TN
    Posts
    2,022
    Default
    Quote Originally Posted by broughtonfilm View Post
    Yes, if we want to be terribly technical and talk like engineers. But if we're not engineers then those words have slightly broader meanings.
    Resolution is also confusing when used technically, because we can talk resolution in terms of MTF, but resolution is also an appropriate word to discuss different frame sizes, and since we're discussing a camera with multiple frame size options, as well as in this instance multiple options for reading the sensor, this can all get quite confusing quite fast.
    I apologize if my attempt to use laymen's terms did not read clearly for you.
    James Houk, DoP
    Sony F35
    Sony PXW-FS7
  7. Collapse Details
    #17
    Senior Member marvinhello's Avatar
    Join Date
    Jul 2011
    Location
    GTA, Canada
    Posts
    893
    Default
    Full scan with default 4K OLPF = image with heavy moire/aliasing in certain situations
    Centre scan with default 4K OLPF = little softer (than normal scan) but nice clean image.
    On F5/F55 there is a "HD/2K Modulation" feature that tones down the perceived sharpness of the image (in normal scan) a little which is pretty nice.
  8. Collapse Details
    #18
    Senior Member
    Join Date
    Dec 2011
    Location
    Florida
    Posts
    2,359
    Post
    We're probably all guilty of misunderstandings in his thread. No big deal.
    But let's look on the bright side - THE FS7 IS GETTING CENTER SCAN!! This is huge.
    If the FS7 wasn't the best bang for the buck of any camera in history already, this takes it up another notch.
    And I will be completely shocked if the center scan only applies to HFR. I'll bet we have it in normal shooting modes too.
  9. Collapse Details
    #19
    Senior Member cuervo's Avatar
    Join Date
    Jun 2008
    Location
    New Mexico
    Posts
    1,210
    Default
    Quote Originally Posted by marvinhello View Post
    +1
  10. Collapse Details
    #20
    Senior Member
    Join Date
    May 2009
    Location
    Missoula Montana
    Posts
    999
    Default
    Is center scan on the f5/55 an instant button push thing or a go into the menu and reboot kind of thing?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
