Page 8 of 8 FirstFirst ... 45678
Results 71 to 76 of 76
  1. Collapse Details
    #71
    Senior Member
    Join Date
    Mar 2012
    Posts
    158
    Default
    Here is the picture of my fs7 hélix rig, lighter as possible. Everything is powered by v-mount battery. Here is settings i put in BGC software.
    2 out of 2 members found this post helpful.
  2. Collapse Details
    #72
    Senior Member
    Join Date
    Mar 2012
    Posts
    158
    Default
    lighter with A7RII and very good AF with Batis 25mm. Everything is powered by Hélix battery.
    I asked to sony why when we plug smallHD monitor we can't use face detection in 4K. I hope sony can resolve this via firmware.
    I use same BGC software setting than FS7 without any problems.
    For powering A7RII i removed lemo protection of hélix NP-FW50 to 2 pin connector dongle because there isn't enought space to plug it. Make shure you nerver inverse polarity. (white cable on red dot optional power plugs).
    here a litle test with A7RII AF + Face detection:
    https://vimeo.com/158755236
    1 out of 1 members found this post helpful.
  3. Collapse Details
    Here is a Picture
    #73
    Junior Member
    Join Date
    Dec 2015
    Posts
    4
    Talking
    Quote Originally Posted by jasonbrooks View Post
    Sure thing, apologies for doubting your authenticity. Could you post some photos of your Omniview setup with the FS7?
    Cheers,
    jason
    Sorry for the delay, i have been busy and didn't check the forum. i took a quick Picture of the gimbal and my FS7, i didnt set up the Follow focus and Monitor but u can see there is enough space to for a lot of stuff on it. The gimbal has a joystick on it and has built in Bluetooth to control it wireless using your phone. i dont tend to use those features my self as im a one man show but if you have a team i could see it come in handy. The gimbal uses 3S Lipo batteries, i have a bunch of 3200Mah which tent to give me about 5-6 hours of run time. The company i got this gimbal from did mention with a 5000Mah you can get about 8-10 Hours of run time.
    In this case i used a big battery for the FS7 (BP-U90) but the smaller batteries seem to work fine as well.
    The gimbal uses SimpleBGC to program, so if your familiar with that program you can tune it to your liking. i have used simple BGC my self so i ended up making my own profile to better suit my needs in terms of speed and follow modes.
    www.omniviewtech.ca
  4. Collapse Details
    #74
    Junior Member VisionRouge's Avatar
    Join Date
    Apr 2017
    Location
    Hong Kong Shanghai Shenzhen
    Posts
    11
    Default
    Another succeful setup with a Ronin M (Way lighter to carry around compare to Ronin full size) and also easier to drop in a bage.
    The right handle is the one from Sony, so you can control most of the camera order without the help of an second operator.
    Also, the top plate is modified, so the same handle can be use on the gimbal and on the camera for a very fast switch between configuration
    The screen also move from the camera to the top of the ronin. Only one screen, only one handle... lot of room in your bag!
    And
    I have a plate to connect it to the vinten tripod without any need for switching it.
    You can follow the full description here.
    http://www.visionrouge.net/web/2017/...n-dji-ronin-m/
    Most of the item come from smallrig, but other brand have similar setup.
  5. Collapse Details
    #75
    Senior Member legrevedotcom's Avatar
    Join Date
    May 2011
    Location
    Copenhagen
    Posts
    1,639
    Default
    Quote Originally Posted by Clermond View Post
    Ronin itself has 4.2 kgs
    FS7 as shown with 16-70z plus SmallHD with single LP E-6 3.0kgs
    That would mean that you could potentially fly it on a Crane 2 IF it's not too long for the mounting point.... I know you can fly an FS5 on a Crane 2.
  6. Collapse Details
    #76
    Senior Member
    Join Date
    Mar 2012
    Posts
    158
    Default
    Here FS7 on letus helix mg with SmallHD focus bolt 500 tx and Tilta nucleus bundle for focusing alone or with an focus puller.
    Weight 5.3Kg perfect combo for 4k 50P full frame tamron 35mm an 45mm stabilised VC and speedbooster iris @ 1.3 full open.HELIXlow.jpg
Posting Permissions
  • You may not post replies
  • You may not edit your posts
