Page 3 of 6 FirstFirst 123456 LastLast
Results 21 to 30 of 52
  1. Collapse Details
    #21
    Bronze Member
    Join Date
    Nov 2004
    Location
    Newyork City
    Posts
    1,005
    Default
    Barrett is the man!
  2. Collapse Details
    #22
    Senior Member
    Join Date
    Jan 2009
    Location
    Terrel, TX
    Posts
    104
    Default
    Hi Hunter,
    I'm not sure if this has been covered elsewhere, and if it has, I'll just delete it. But after several reads, I'm not sure if it's clear to everyone how the speed-booster works, and what the underlying pre-requisites are for its ability to make a brighter picture.
    Although I have no personal contact with the metabones team, the concept behind the speed-booster is simply to change the total optics characteristics to focus a smaller image onto a given sensor. This is what makes the final image brighter - the light is being concentrated into a smaller area or circle. If you reduce the radius of the final image by Sqrt(2), the brightness will increase by a full stop (same math as applied to the inverse-square law for lighting). For example, if you have a lens that makes an image circle radius of 1.7 inches, and then add an adapter that shrinks that image down to a circle radius of 1.2 inches, (a reduction of only 1/2 inch), the brightness in that circle will have doubled, gaining 1 stop! Note that for a 1 stop gain you are working with a lens that has a crop value of 1.4 for that sensor.
    So if you have a taking lens designed to fully cover a 35mm full-frame, it will have a circle radius of at least 21.8mm and area of 1490 sq-mm. If you have a sensor for the Black Magic Pocket Cinema Camera (BMPCC), its circle of coverage needs to be no less than 7.2mm, and have an area of 161 sq-mm. Theoretically, one could boost the brightness of the 35mm full-frame lens by 9.2 times if it were to be reduced to fit the BMPCC sensor. (Area of lens/Area of circle over sensor = theoretical max gain brightness if area of lens can be matched to that of circle needed to cover the sensor).
    However, the real world is different from theory. Keeping the image perfect, while bending all light into a much tighter circle is one challenge. Changing the mounting setup for the sensor would be the other, as the focal distance gets considerably shorter the more you shrink the image-circle. This may have been the most difficult thing for metabones to overcome, and may be an area where custom front ends on the F35 could more easily overcome.
    But despite the possible gain of 3.2 stops for this setup, Metabones can "only" gain 1 2/3 stops, and take the crop from 3 to 1.75, when going from a full-frame 35mm lens to an image sensor that can be completely covered by a 7.2mm radius circle. So physical/economic limitations do exist.
    If you look at metabones data on their adapters, you'll see they don't get their adapters down to a crop value of 1 - presumably because of these limitations. For the M43 converter, they take the picture circle down just far enough to give them a crop of 1.42. Even though an M43 sensor can use a picture circle as small as 10.9mm radius - and could have a theoretical gain of 2 stops from a full-frame 35mm lens, their adapter goes no smaller than 15.3mm radius, allowing for "only" 1 stop gain. I point this out to show difficulties with reaching theoretical performance.
    If one were to try and make gains on a full-frame 35mm lens to the Sony F35, the total theoretical gain in brightness would be 1490 sq-mm /584 sq-mm, yielding 2.55 or 1.35 stops. The fact that the theoretical gain from full-frame to M43 was 2 stops, but metabones only gained 1 stop, might make one pause to consider the potential difficulties of getting even 1 stop gain on the F35. If physical conditions can only achieve 1/2 of the theoretical, starting with 1.35 stops theoretical gain may not be worth the struggle.
    However, if you were to start with lenses designed for much larger image circles, you could gain a lot more brightness - if the larger format lenses started at the same f numbers as the full-frame lenses do!
    Take, for example, a Bronica 75mm f/2.8. It's image circle radius would be larger than 42.5 mm, with a minimum area of 5,674 sq-mm!!! If divided by the F35 image circle of 584 sq-mm, we see a theoretical gain of 9.7 or 3.3 stops!
    Getting all that glass perfectly positioned opposite the sensor might be a challenge, but even if you sacrificed that number by half, you'd still make tremendous gains.
    An easier way to estimate light gains is to divide the radius of the image picture - created by a lens - by the radius of the image circle needed to fully encompass the sensor. Then square your answer.
    For instance, a typical full-frame 35mm lens creates an image circle radius of 21.8 mm. The Black Magic Cinema Camera has a sensor of dimensions 15.81mm x 8.88mm, needing an image circle radius of 9.07mm.
    So we take 21.8 / 9.07 = 2.40.
    Now, 2.40 squared equals 5.76.
    Possible gain in brightness is 5.76 or 2.5 stops. Metabones achieves 1 1/3 stops. Their crop factor is 1.53. Crop is calculated by dividing radius of taking lens by radius of image covering sensor. For BMCC, a 35mm full-frame lens experiences a crop of 2.4. If metabones could have reduced the crop down to 1, they would have gained almost 2 1/2 stops.
    Interestingly enough, if you know the crop value of a lens to a sensor, you can simply square that number (ie. square 2.4 is 5.76) to get the light magnification possible if the "perfect" adapter could be made for that lens. In this case, max possible gain would be 2.5 stops.
    That said, trying to speed boost a Cooke Pancro, for instance, with an image circle radius of around 15.6 mm, to the Sony F35 sensor (covered by radius 13.64 mm), you get a max theoretical gain of 0.20 stops. No point in even trying to speed boost that.
    Last edited by Sandbox; 02-03-2014 at 05:04 PM. Reason: Fixed some brightness-gain to stops conversions. A brightness gain of 8 is 3 stops, not 4 :p
  3. Collapse Details
    #23
    Senior Member
    Join Date
    Oct 2012
    Location
    Seattle, WA
    Posts
    349
    Default
    TL;DR:
    Take that money and buy a truck of used Mole Richardson Fresnels.
    No, seriously great info, Sandbox. Thanks for sharing all that science. I feel smarter just being in the same room as you.
  4. Collapse Details
    #24
    Default
    Good info, but my brain hurts now.
  5. Collapse Details
    #25
    Senior Member Hunter Hampton's Avatar
    Join Date
    Feb 2007
    Location
    LA
    Posts
    2,895
    Default
    Great info Sandbox- Yeah I was talking about mainly "speed boosting" 35mm slr lenses, or rehoused 35mm PL lenses- I think your right about the FFD being an issue or needing adjustment.
    Based on your post, I have some new ideas for taking medium format lenses and shrinking down the image circle to super35mm- that might get us some very fast lenses no? Basically what I really want is an affordable sharp 0.95 to be able to use on the f35 in certain night scenes.
    Hunter Hampton
    hunterismyfriend.com
    vimeo.com/hunter
  6. Collapse Details
    #26
    Senior Member
    Join Date
    Oct 2012
    Location
    Seattle, WA
    Posts
    349
    Default
    The E. German Zeiss Jena Pentacon 6 lenses are medium format, some of them reasonably fast at 2.8, too. Taking the 30mm 3.5 Zodiac Pentacon 6 and speedboosting that would be an interesting experiment if it could be done. I don't know the math, but even if you could get an extra stop down to f2 and widen it up to 25mm or so you'd have a very workable solution. And the mount can stay PL, too.
  7. Collapse Details
    #27
    Senior Member
    Join Date
    Feb 2008
    Location
    San Diego
    Posts
    214
    Default
    Allstar has a hasselblad-pl adapter which may play a nice role in our goal. Possibily contract metabones to create a hasselblad speedbooster? Could mean $$$ to them, and a whole new portal of fun for us!
    http://allstar-cine.myweb.hinet.net/..._M_adapter.htm
    https://vimeo.com/42560661
  8. Collapse Details
    #28
    Senior Member
    Join Date
    Jan 2009
    Location
    Terrel, TX
    Posts
    104
    Default
    Think of the medium format lenses (for the F35) as the equivalent of going from 35mm full-frame lenses down to a BMPCC sensor! Lots of room for gain. 3 stops plus, in fact. That would get a 2.8 down past 1 in a perfect world.
    Getting those gains, however, will mean getting the crop factor down near 1. And doing that without introducing aberration might be a challenge - but there may be a work-around for that, too, if you're crazy. And because you're already talking about taking the lens mounting plate off the F35, your freedom to move glass closer to sensor will give you much more freedom than metabones had with their product line. So there definitely seems to be a chance with this option.
    Regarding potential aberration issues - there was an article about cameras of the future handling aberration and other lens-related issues by processing the image in-camera, so that the need for expensive lenses could be done away with.
    The proposition was that as long as the camera "knew" what the deficiencies of the taking lens was, and could manipulate the pixels back to where they needed to be, prior to recording them, the camera could capture imagery just as sharp as a perfect lens, but using a single element plastic lens instead.
    If you think about it, light's behavior is mathematics, and if you know where a lens is failing to keep things lined up, and you sample it sufficiently, you should be able to apply formulaic corrections to the picture prior to recording it.
    This got me thinking of the possibility of fixing image degradation caused by using "inexpensive" lenses or, in this case, an inexpensive optical adapter (which may be a problem, as a "perfect" solution might cost thousands).
    Each adapter/lens setup could, theoretically, be "diagnosed."
    You could begin by capturing footage of a detailed black and white grid, and import a plate into an application like Nuke, where one could not only correct distortion, but manipulate each color channel independently, using warp maps, until all the pixels line up to give a sharp, clean image.
    Lens distortion could then be re-introduced, but the picture could be pristine if done right. And each solution would stay married to that lens/adapter combination forever (assuming we're talking about primes).
    Now I haven't experimented with it myself, and there might be other variables introduced by changing F-stops. But if you're using an adapter, it's probably for a particular application, and probably wide-open, so I think the possible variables could be ignored.
    Once the lens setup is evaluated and solved, all footage shot with that setup could be fixed with this solution effortlessly. And workflow wouldn't even require the image to be "fixed" until final edit, just before going into color. So I don't think it would hurt workflow that much, while offering quite a gain.
    This is assuming that bringing an image from crop-factor of 3 to crop factor of 1 is going to bring some optical difficulties. If the adapter can handle all this without degradation, then I'm just wasting your time with another TL/DR
  9. Collapse Details
    #29
    Senior Member
    Join Date
    Oct 2012
    Location
    Seattle, WA
    Posts
    349
    Default
    VFX butters its bread with pre-baked recipes for everything from CG lighting solutions to color correction to pre-comps to...well, anything you can imagine. Adding a lens correction recipe would just be another log on that fire and would slot pretty seamlessly into any given pipeline. I recall a few months back reading about somebody who released an After Effects comp file that emulated a 40mm Anamorphic lens. Distortions, blurs, vignette- the whole shebang. This is pretty straight forward stuff, really. The thing that's really hard to do in post is make soft images sharper. That requires a bit more magic sauce than your typical VFX production artist possesses. You need straight up optical engineering algorithmic programming help, and even then results are sketchy. If it were easy it'd already be a plug in for Photoshop.
  10. Collapse Details
    #30
    Default
    Quote Originally Posted by Barrett Phillips View Post
    In other news Dave's been designing an interchangeable lens mount system for me because he's the man (ie. a system allowing mount swaps without having to remove the front plate) to switch between PL, Nikon or EOS by changing a few screws on the front and also giving a lot more room around each lens. I'll update as it progresses, probably in a new thread. Exciting times!
    as a non-current, but hopefully soon to be F35 owner, this sounds like a dream. just figured I'd share some more outside interest in this
Posting Permissions
  • You may not post replies
  • You may not edit your posts
