Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 30
  1. Collapse Details
    #11
    Senior Member joe 1008's Avatar
    Join Date
    Dec 2005
    Location
    Barcelona
    Posts
    1,078
    Default
    Quote Originally Posted by Samuel H View Post
    * You're right, my statement that "A 4K image with 8-bit 420 color has enough information to give you a 2K image with 10-bit luminance and 8-bit 444 color" is only 100% true if you record uncompressed.
    * On my NEX-5N (1920x1080 at 24fps with 8-bit 420 color encoded into 24Mbps), the 420 part throws away half the original information, then the codec throws away 96% of what it receives. Mostly redundant stuff, really...
    So it's no real workaround using 4k footage with a low end codec to get better quality HD footage. I was wondering how the 4K 60Mbps of Sony's FDR-AX100 would play out in HD compared to the native HD codec with 50Mbps. Now I suppose it wouldn't be worth the extra work.
  2. Collapse Details
    #12
    Senior Member
    Join Date
    May 2010
    Posts
    2,449
    Default
    Quote Originally Posted by joe 1008 View Post
    Only if the post downscale is better than what the camera has built in. Could be some minor improvement, but the camera is working from 14 bit or 16 bit raw data internally.
  3. Collapse Details
    #13
    Senior Member
    Join Date
    Oct 2005
    Location
    London, UK
    Posts
    1,285
    Default
    I'm somewhat intrigued with the possibility to get kind of a 10bit HD image out of a 4K 8bit image. It might be as simple as converting H264 HD files into PRORES with the extra benefit of using more of the codec's possible colour space.
    I'm assuming that what Samuel H was alluding to was that in a simple case, you average 4 4K pixels to get a single 2K pixel. Averaging the pixels should average the noise as well, hence the idea of 10 bit from 8 bit?
    I'm not sure it's quite as straightforward as that, and a lot may depend on the noise level of the camera. Perversely, the more noise free the camera, the less that scenario may be the case.
    Imagine as an example 4 pixels in a block, three of which have the 10 bit value 0000000011 (3) and one has 0000000100 (4). In an 8 bit system, rounding will give all four the same value - 00000001 (equivalent to 4in the 10 bit system).
    Convert to 2K, and the averaged (10 bit) value in the first case will be 13/4=3.25 - which will round to 0000000011 (3).
    Do the same averaging derivation for 10 bit for the original 8 bit case, and the result will remain 4 (0000000100)
    That's an extreme example, obviously, but it's to try to show the principle that once you've lost integrity by rounding to 8 bit, you can't necessarily retrieve it by the averaging process.
    In a system with a higher noise level (higher than the bit depth) then the averaging may well reduce the noise level - but that's a different matter to bit depth improvement. Practically, I don't think you'll win, and I think the most fundamental feature is the size of the sensor chip. Put more photosites onto it, each will be smaller, hence noisier, but an averaging will reduce the noise level again. Put just enough for required resolution - and they will be bigger, quieter - but you can't then do any further trickery. I suspect the results in each case will be similar.
    None of that is to say that you don't get any advantage in doing post work at 10bit after 8bit acquisition - you do, by less rounding truncation - but I don't think it's true to equate 4 8-bit
    samples with a single 10-bit sample.
    The colour subsampling is a different matter. Both 4K 4:2:0 and 2K 4:4:4 have exactly the same number of chroma samples per frame - 1920x1080 for quad-HD. Hence to all intents and purposes then 4K 4:2:0 should correspond in chroma terms to 2K 4:4:4.
    Whenever you hear, "4K, but only 4:2:0!?!" then just remember that such will have twice as many chroma samples as 2K 4:2:2 (1920x1080 versus 960x540)
  4. Collapse Details
    #14
    Join Date
    Dec 2005
    Location
    Barcelona
    Posts
    1,078
    Default
    You make a valid point here demostrating that the result can't be real 10 bit. But won't there be in most cases a result from averaging those four 8bit pixels that could be described with more precision by 10bit?
    Or, in a real world situation: Even grading 8 bit carefully easily causes banding. Could a "fake" 10 bit codec protect my footage better from banding? (Of course it would have to be very clean, otherwise those 10 bits, as you wrote, would only show grades of noise - which itself, however, helps to avoid banding.
    But ayway, 4:4:4 alone might be worth the conversion to HD, adding the advantage of an easy 2K workflow.
  5. Collapse Details
    #15
    Senior Member James0b57's Avatar
    Join Date
    Dec 2008
    Posts
    4,271
    Default
    The ugliest 8bit banding is usually in much larger blocks than 4pixels, so rounding down, and even approximating pixels into a 10bit space won't help 8bit banding issues for the most part. Also, it does not increase color accuracy.
    Though, I wonder if there are any plugins or applications which address 8bit gradients by creating intermediate steps?
    wall gradient crop by onesielaff, on Flickr
    8bit Grad Graded and Compressed by onesielaff, on Flickr
  6. Collapse Details
    #16
    Senior Member David W. Jones's Avatar
    Join Date
    May 2010
    Location
    La Petite Roche
    Posts
    6,742
    Default
    Sometimes I have to laugh at this whole it's gotta be 4K or it's crap mentality. My current camera will shoot 5K, and my last camera would only shoot HD. But my HD F35 had a much more pleasing look than my 5K Epic. Replaced an XH-A1 with a Red One M, replaced the Red One M with an AF100, replaced the AF100 with an F35, replaced the F35 with a Red Epic X. No telling what camera we will use next year.
  7. Collapse Details
    #17
    Senior Member Grug's Avatar
    Join Date
    Apr 2007
    Location
    Melbourne, Australia
    Posts
    3,792
    Default
    Downscaling 4k to HD doesn't give you more colour resolution - it gives you more colour resolution 'per-pixel'.
    There's a difference.
  8. Collapse Details
    #18
    Senior Member Samuel H's Avatar
    Join Date
    Jun 2010
    Location
    Madrid, Spain
    Posts
    7,981
    Default
    Exactly, you get more color resolution per pixel, but less pixels. It doesn't create any new information.
    Let me go through the details because I think there's some confusion as to what I meant with the 10 bit thing...
    In 4K 420 footage (let's make it UHD for simplicity), you have 3840x2160 8-bit luminance values, and 1920x1080 8-bit chroma value pairs. It's clear already that you're going to end up with 444 8-bit color because all the info is there to begin with. For luminance, you're mixing four 8-bit values to get the value of the new (bigger) pixel. When you mix four values ranging from 0 to 255, how many options do you have for the result? 1024 different options. That's one 10-bit luminance value, which you get by adding the four 8-bit values, instead of averaging them. You could also average them and stay in 8-bit world, but then you're throwing information away.
    Now, if compression is giving you a macroblocked image to begin with, there will be much less variation among those four values, and all this flies out of the window. So, the devil is in the details.
    BTW, all you have to do to make good use of this is to drop your 4K file into a 1080p timeline in Premiere and give it 50% size, no transcode necessary.
    You can test it right now with your current footage: go for a clip where you wished you had 10-bit color, make it 50% size, do you still see the issues that were bothering you? It will depend on the camera, on my NEX-5N it would probably be a yes, on the C100, even though it is also H.264, I would guess it's a no. On the NEX, the problem is not 8-bit, it is a lousy implementation of the codec.
  9. Collapse Details
    #19
    Join Date
    Dec 2005
    Location
    Barcelona
    Posts
    1,078
    Default
    Good one.
  10. Collapse Details
    #20
    Senior Member joe1946's Avatar
    Join Date
    May 2009
    Location
    Millstone,NJ USA
    Posts
    1,553
    Default
    From what I seen at CES all the the TV companies are putting more DR and a wider color gamut in UHD TVs than HDTVs. Just because some people can't see the difference in a 2mp image from an 8mp image does not mean technology will come to a stop.
    GH5, Sony FDR-X3000,Nikon P1000 , a6300 , NX1 , GH4 , Leica DG Vario-Elmarit 8-18mm f/2.8-4 , Leica DG Nocticron 42.5mm f/1.2 ASPH Power OIS , Voigtländer Nokton 25mm f/0.95 ,Olympus M.Zuiko Digital 75 mm f/1.8 ED , 100-300mm F/4.0-5.6 OIS , Sony A7r , FE 70-200mm F4 G OSS , Sony Zeiss Sonnar T* FE 55mm f/1.8 ZA ,Sony Zeiss Sonnar T* FE 35mm f/2.8 ZA , 28-70mm FE OSS, 15mm F2.8 , 24mm F1.4, 50mm F1.4, 85mm F1.4
Posting Permissions
  • You may not post replies
  • You may not edit your posts
