Page 1 of 2 12 LastLast
Results 1 to 10 of 18
  1. Collapse Details
    Transferring DVX tapes with Mini DV camera?
    #1
    Senior Member Raptor3400's Avatar
    Join Date
    Aug 2003
    Location
    Atlanta, USA
    Posts
    154
    Default
    I recently sold my DVX100 but before I did i transfered all my 50+ tapes to my computer. Well, of course after I sold the camera I lost a lot of the footage by way of a hard drive error. I was wondering if I can buy a cheap Mini-DV camera to re-capture the footage. Will regular Mini-DV equipment read the DVX100 footage. Thanks.
  2. Collapse Details
    #2
    Senior Member
    Join Date
    Mar 2010
    Posts
    404
    Default
    I believe that if it was shot at 24p, then it needs to be played in the DVX. Otherwise any camera should do.
  3. Collapse Details
    #3
    Join Date
    May 2005
    Location
    Illinois
    Posts
    38
    Default
    DV is DV. Any mini-DV cam should be able to move the video to computer.
  4. Collapse Details
    #4
    Senior Member Allan Black's Avatar
    Join Date
    Nov 2004
    Location
    Loose Gravel Sydney.
    Posts
    1,179
    Default
    Agreed, just rent one.
    Cheers.
    35yrs with our own a/v production company and studios.
  5. Collapse Details
    #5
    Join Date
    Aug 2003
    Location
    Atlanta, USA
    Posts
    154
    Default
    Thanks for the replies, guys.
  6. Collapse Details
    #6
    Default
    To really spell it out, yes, any DV camera can play back DVX tapes, including the 24p tapes.
    However, be aware that if you shot in LP, there is no guarantee that any camera or deck will be able to play back any other camera's LP footage.
    1 out of 1 members found this post helpful.
  7. Collapse Details
    #7
    Moderator David Jimerson's Avatar
    Join Date
    Oct 2003
    Location
    Wilmington, NC
    Posts
    27,901
    Default
    Also, using any camera, all of the metadata will be transferred, so the 24p pulldown flags will still be intact, so automatic pulldown removal for editing as 24p is still possible.
    LEARN FILMMAKING - DIGITAL STREAMING AND DOWNLOADS OF GREAT TRAINING PROGRAMS!
    WRITING FOR TELEVISION ARTICLE | "ASSUMPTION BLUES" FILM NOIR RADIO PLAY | "BLUE SCARLET" RADIO PLAY
  8. Collapse Details
    #8
    Senior Member arielman's Avatar
    Join Date
    Jun 2005
    Location
    Belleville Ont Canada
    Posts
    787
    Default
    I had bought a cheap camera to capture with to save my DVX 100.
    The problem is the 2332 pull down is not there and neither is progressive mode even with the project set to progressive and 24 frames
    So I go to each clip and change change the properties from lower field to progressive and export as an AVI file.
    Importing then shows 23.97 and 2332 removed.
  9. Collapse Details
    #9
    Join Date
    Oct 2003
    Location
    Wilmington, NC
    Posts
    27,901
    Default
    What NLE are you working in?
  10. Collapse Details
    #10
    Join Date
    Jun 2005
    Location
    Posts
    787
    Default
    I use Vegas 7 David
    Ian
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
