Page 1 of 2 12 LastLast
Results 1 to 10 of 18
  1. Collapse Details
    GH3 GH2 multi-aspect ratio sensor explanation
    #1
    Default
    Greetings folks,
    I had asked around here for an explanation about all the hub-bub relating to the GH3 not having a multi-aspect ratio sensor, even though it listed as having multiple aspect ratios. I got a few explanations, but none of them were any good. So I did some digging around the interwebs and I finally get it now, and I made a diagram! Unless I am wrong, then ignore everything!
    First a simple explanation. It is as simple as this, a multi-aspect ratio sensor can give you multiple aspect ratios while keeping the same effective sensor size. This is the key part which seemed to elude people when trying to explain it to me. Sensor sizes are measured diagonally. The GH2, when choosing an aspect ratio, will always keep an effective sensor size of ~22mm, whereas with the GH3, only the 4:3 aspect ratio is ~22mm.
    Here is a diagram I whipped up. As you can see, the effective size of the sensor for the GH3 is variable, but still quite acceptable. Hope this helps!
    Attached Images Attached Images
  2. Collapse Details
    #2
    Default
    Not quite accurate yet.
    Here's a great diagram, originally from Bjorn Utpott at www.bmupix.com but re-posted at http://www.pattayadays.com/2010/12/p...ic-gh2-review/
    6C52263CC2B84C7BBFE30FCC3519D7B4 by pattayadays.com, on Flickr
  3. Collapse Details
    #3
    Default
    This site has a good explanation as well:
    http://m43photo.blogspot.com/
    The multi aspect sensor feature means that the sensor is over-sized. At any one time, the whole sensor area is never used. But various parts of the sensor area can be used, to enable 4:3, 3:2 and 16:9 aspect ratios, while retaining the same diagonal field of view. This uses the lens imaging circle more efficiently, especially in video mode.
  4. Collapse Details
    #4
    Default
    @ErikTande Exactly.
    @atarijedi
    Now this next part is based on the above estimated data.
    GH2 sensor in 4:3 = 17.3x13
    GH3 sensor in 4:3 = 17.3x13
    GH2 sensor in 16x9 = 18.8x10.6
    GH3 sensor in 16x9 = 17.3x9.7
    So the crop factor with the lenses you use will be different in video mode now.
  5. Collapse Details
    #5
    Default
    You're right, all my numbers match Bjorn Utpott's, but my diagram doesn't seem to line up, and I didn't save the psd. Oh well. I blame my slow computer...
  6. Collapse Details
    #6
    Default
    GH2 doesn't keep the same angle of view with 1:1 crop is the only mistake.
    Kind of sucks that your lose some of your wide end on your lens if you are used to the GH2, but that also presented some problems since certain lens would vignette more heavily on the GH2. Kind of disappointing they didn't keep the design.
  7. Collapse Details
    #7
    Senior Member
    Join Date
    Nov 2009
    Location
    Cary, NC
    Posts
    1,285
    Default
    And here is a demonstration of what the different aspect ratios of the GH2 and GH3 will look like.
    http://www.youtube.com/watch?v=zFnY5tlvW8M
  8. Collapse Details
    #8
    Default
    Eh, I understand why some people are worrying about this because I too felt that little pang of anxiety when I heard this, but I've since chilled out. What percentage loss is that going to be in diagonal frame size? Let's see, based on Per's estimations of the 16x9 dimensions above:
    GH2 16:9 diagonal: 21.58
    GH3 16:9 diagonal: 19.83
    A loss of 1.75mm, or ~8.1% diagonal frame size. I think it will be barely noticeable in practice, and easily adjusted for in most cases. There may be some advantages too, like bradleyg5 mentioned, of reducing vignetting and unsharp corners on certain lenses.
    If someone can come up with the 16:9 dimensions of a full-frame sensor, we can come up with the exact crop factor for the GH3 (depending on accuracy of estimations and calculations so far). I couldn't find those numbers on a quick search.
  9. Collapse Details
    #9
    Default
    I did some more digging and found the diagonal dimensions, thanks for Abel Cine's field of view comparator:
    5D (most similar to full frame "135" 35mm still photography film: 41.3mm (crop factor: 1x)
    Super 35 motion picture film: 28.5mm (crop factor: 1.45x)
    7D and D3100: 26.8mm (crop factor 1.54x)
    GH2: 21.58 (crop factor 1.91x)
    AF100: 20.1mm (crop factor 2.05x)
    GH3: 19.83 (crop factor 2.08x)
    My numbers are a little off from what I traditionally have heard (i.e. 1.5x for Super 35, 1.6x for APS-C, 1.86x for GH2), but that could be due to rounding errors somewhere. The point though is that all the m4/3 cameras are right around the neighborhood of 2x crop factor, give or take a few hundreths.
  10. Collapse Details
    #10
    Default
    @Shenan Looks right.
    According to that, the difference between the GH2 and GH3 is 0.17x crop factor. That's just about a 12mm difference at the telephoto end of my 24-70mm and a 4mm difference at the wide end.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
