Results 1 to 5 of 5
  1. Collapse Details
    F5 scene, 24p - No audio recording. Why?
    #1
    Junior Member jcmontero's Avatar
    Join Date
    Feb 2011
    Location
    Milan, ITALY
    Posts
    14
    Default
    Hi, as per title, I have set my 250 to scene F5 in order to shoot @ 24fps. When I switch to that setting a barred A.REC alert appears and no audio is recorded. Is this correct? How to avoid this issue?
    It also happens on both my 250's and on my 171.
    No problem on the DVX100.
    Thanks for the help!!!
    JC
  2. Collapse Details
    #2
    Resident Preditor mcgeedigital's Avatar
    Join Date
    Apr 2005
    Location
    Potomac Falls, VA
    Posts
    7,886
    Default
    If you in VFR, no audio will be recorded.
    Turn VFR off.
    Matt Gottshalk - Director/ Dp/ and Emmy Award Winning Editor
    Producer, Digital Creative for the United States Postal Service
  3. Collapse Details
    #3
    Join Date
    Feb 2011
    Location
    Milan, ITALY
    Posts
    14
    Default
    Matt,
    Thanks for the reply.
    I turned VFR off, but not it records in 25PN, not 24P.
    Scene F6, with VFR on records in 24P but without audio.
    JC
  4. Collapse Details
    #4
    Senior Member
    Join Date
    Apr 2008
    Location
    Montreal, Canada
    Posts
    315
    Default
    i think that is because you are in Italy and you're suppose to record in Pal(50hz).
    If you want to record in 24p just switch it in 60hz(NTSC) so you won't be in VFR at 24 frames.
  5. Collapse Details
    #5
    Join Date
    Feb 2011
    Location
    Milan, ITALY
    Posts
    14
    Default
    kabtv,
    got it!
    I switched to 720-59.94 and then AVC-I100 /24PN. It works perfectly.
    I also found out to stay in 720-50P and then AVC-I100 /50P instead of 25PN.
    It records audio, but it greatly lowers the card capacity.
    Thank you!
    JC
Posting Permissions
  • You may not post replies
  • You may not edit your posts
