See the top rated post in this thread. Click here
Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. Collapse Details
    Cheapest(and quickest) way to improve acoustics in empty room(wood floor, brick walls
    #1
    Default
    Hi
    For an upcoming shoot I will be filiming a singer in an empty room with a minimum number of props to make it seem like an apt.
    Can anyone suggest some quick and inexpensive ways to improve the acoustics and cut down on the echo?
  2. Collapse Details
    #2
    Section Moderator Alex H.'s Avatar
    Join Date
    Sep 2008
    Location
    Knoxville, TN
    Posts
    6,415
    Default
    1) Absorbent wall hangings, area rug, overstuffed furniture; furni pads hung on sides, just out of frame, and behind the camera.
    2) Pre-record the music and have the singer lip-sync to playback.
    Formerly known as C2V
    Nobody notices audio... until it's not there.
    For Sale: Yashica ML Prime Lenses
    1 out of 1 members found this post helpful.
  3. Collapse Details
    #3
    Default
    Two words:
    'MOVING BLANKETS' (usually less than $10 each and re-usable.
    However Alex's suggestion #2 is better.
  4. Collapse Details
    #4
    Join Date
    Sep 2008
    Location
    Knoxville, TN
    Posts
    6,415
    Default
    Quote Originally Posted by Rick R View Post
    'MOVING BLANKETS'
    ... aka "furni pads" or "furniture pads".
  5. Collapse Details
    #5
    Senior Member John Willett's Avatar
    Join Date
    Aug 2007
    Location
    Oxfordshire, UK
    Posts
    1,180
    Thumbs up
    Cardboard boxes - and duvets are superb for absorbing sound.
    John Willett
    Sound-Link ProAudio Ltd.
    Circle Sound Services
    President - International Federation of Soundhunters (FICS)
    Chairman - British Sound Recording Association (BSRA)
    Recorder: Nagra VI, Nagra SD, AETA 4MinX
    Mics: (all pairs): Sennheiser MKH 20/30/40/800/8020/8040/816F, Neumann KM-D series. Plus: Soundfield SPS200, Neumann TLM 103, KMR 81i + loads more
    DAW: Sequoia
    Monitors: Geithain RL906, Harbeth M30A, K+H O110D
    Headphones: Sennheiser HD 25-1, HD 800
    Monitor Controller: Grace m903
  6. Collapse Details
    #6
    Senior Member
    Join Date
    Oct 2008
    Location
    cornwall UK
    Posts
    3,344
    Default
    Cardboard boxes - my kind of tech
    Can you offer advice on the arrangement
    for example I guess if they have no 'lid' and are tipped on the side, and the placed at an angle to the source sound to kind of 'catch' it?
    S
  7. Collapse Details
    #7
    Default
    People call me crazy but...
    Moving blankets (the quilted kind) loosly streatched over a wood or PVC frame. They can be laid on floor, leaned against the wall, hung on the wall, suspended overhead, etc. When against the wall or floor, the gap helps it to capture sound that does bounce back fro the wall as well.
    The world is full of examples of fantastic talent that never went through formal training.
    Their strongest gift was perseverance.
  8. Collapse Details
    #8
    Default
    Don't forget one of the best ways to knock down room acoustics is to place the mic as close to the talent as possible.
    The closer you are the less room you will hear. Seems obvious but keep it in mind.
    Also generally speaking.. in my opinion hearing a bit of the room isn't necessarily a bad thing. Of course if the room is acoustically a disaster try to knock down the reflections as much as you can
    but hearing some of the room that you also see helps create the overall space in the viewers head.
    FS: Lavalier Microphones/headphones http://www.dvxuser.com/V6/showthread...202-headphones
  9. Collapse Details
    #9
    Senior Member Hxd Ped's Avatar
    Join Date
    May 2008
    Location
    Minneapolis
    Posts
    112
    Default
    Quote Originally Posted by morgan_moore View Post
    S
    No. One of the reasons a box works is because it's like a resonating absorber. Not a very good one, but still....
    Put then in the corners and scatter them around to break up the 90 degree angles.
    “If you have to fix it with a computer, quantize-piss-correct it, and overly inspect it, then you can’t do it.”
    -Henry Rollins
  10. Collapse Details
    #10
    Senior Member
    Join Date
    Oct 2008
    Location
    cornwall UK
    Posts
    3,344
    Default
    S
Posting Permissions
  • You may not post replies
  • You may not edit your posts
