Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 36
  1. Collapse Details
    #11
    Senior Member
    Join Date
    Feb 2005
    Location
    Washington, the state.
    Posts
    2,471
    Default
    Rick, suggest this thread be closed.
    Grant
  2. Collapse Details
    #12
    Bronze Member
    Join Date
    Apr 2012
    Posts
    18
    Default
    Not a noob in video. Im a Dop, Editor, Director, Producer, etc, but unfortunately i have not had heaps of sound experience. (dont get me wrong, im not helpless) I use boom mics, wired lapels, and other stuff. Never used cheap stuff. Anyways dont worry guys, i found a few on ebay for $10 for 2, so they will do fine for what i need. Thanks for all the helpless reply's, tell your fingers i said sorry you had to type all that up.
  3. Collapse Details
    #13
    Default
    Jeez, for that money you could buy 8 of these http://www.connevans.co.uk/store/vie...um=feedmanager Problem solved?
    I guess what these guys are saying is, save your $150 budget and instead couple your Scarlet with a potato, as the audio results will be similar.
  4. Collapse Details
    #14
    Bronze Member
    Join Date
    Apr 2012
    Posts
    18
    Default
    Haha but i solved my problem even more. Zoom H1 + 2.4GHZ Lossless audio transmitters (just bare boards, so some hacking to go on here) and a cheap wired lapel. Boom problem solved.
    You guys missunderstand. I already have sound down pat. Im looking for lapel mics that will probably be blown up in the first 10 mins of use, so as long as that potato you were saying picks up sound, im fine. BTW did i mention, this was not even for the final release, just for proxies and what have you? so good quality isnt a problem. Hell, i might just end up using the boom from a distance...
  5. Collapse Details
    #15
    Default
    You sound like a troll to me as there is the usual drip feed of information and then you change your track when challenged.
    Glad you got sorted and thread is now redundant as you found your own solution anyway and chose to ignore our advice!
    Next!
    Over 15 minutes in broadcast film and tv production: http://www.imdb.com/name/nm1044352/
    www.HDProductionSolutions.com
  6. Collapse Details
    #16
    Senior Member Justin Kuhn's Avatar
    Join Date
    Jun 2005
    Location
    NC
    Posts
    1,448
    Default
    Not much point to getting the sound of an explosion with lapel mics of any quality, seems like...
  7. Collapse Details
    #17
    Bronze Member
    Join Date
    Apr 2012
    Posts
    18
    Default
    Thanks. Im no troll. Where have i changed my track? What advice was that may i ask? I set some points, and that didnt match the criteria.
  8. Collapse Details
    #18
    Default
    You asked a question re best $150 lapel mics (wireless in thread title), I answered with a solution around the budget but you seem to have found a better solution down a different track for $10 or with some 2.4g transmitters.
    Hope it works and good luck I personally threw my 2.4 ghz video transmitters in the bin as they didn't work, there is no such thing as a lossless radio system so hope you don't waste your money.
    BTW is this you? http://www.imdb.com/name/nm2252713/
  9. Collapse Details
    #19
    Senior Member
    Join Date
    Jan 2007
    Location
    Hamilton, Ontario, Canada
    Posts
    2,722
    Default
    Quote Originally Posted by Timothy Carr View Post
    Look guys, i appreciate your help, but please answer my question, not create others like "Do you have lighting, thats not much, etc"
    For your information, yes i have good lighting (what made you think it was a night shoot?). I have a boom mic for the rest of the film (if you read the original post) so its this ONE SHOT. I also want these mics because the shot is a explosion, and well i dont want to ruin anything (Ruined my NTG3 before, and couldn't even use the shot because the mic was there). Dont suggest SFX, i probably will add stuff, but i want a sound from the original too.
    Again, i dont want wired stuff, all wireless (as im on a Steadicam and need wireless for the best performance). So PLEASE is there any wireless lapel mics for $150.
    EDIT: I was also thinking what i can do for realtime wireless. I have though about getting a few ZOOM H1 and just hooking mics up that way, and syncing in post. Unless you can get a addon for the h1 that is...
    There are NO ... repeat NO ... wireless lapel mic kits for $150 or less that will produce usable results. Anything in that price range will sound like a tin-can on the end of a piece of string. Rent a proper professional-grade kit for a couple of days. Rental is good enough for the Hollywood studios, it's good enough for the major for the national TV networks, it's good enough for you.
  10. Collapse Details
    #20
    Default
    Tim, My advice to you is, check out what Gary is doing and then ask yourself if you still want to ignore what he saying...
Posting Permissions
  • You may not post replies
  • You may not edit your posts
