Results 11 to 20 of 28
Junior Member
- Join Date
- Mar 2012
- Location
- Denver Colorado
- Posts
- 20
06-05-2012 03:16 PM
Hey so I record audio directly to the camera using this cable.
http://www.bhphotovideo.com/c/produc...ne_to_2_5.html
This allows me to both monitor the audio and record it to the card. So there is no syncing involved. I think this works really well. I use a variety of mics the go into the Zoom H1 then to the sescom cable out to the GH2 and headphones. So far I have not had any issues with this set up.
Here are some photos of my set up.
http://www.crossbowfilms.net/102/
I need to post more of just my camera set up. But there should be a few pics on there that show you how it works.
06-05-2012 08:45 PM
ha. that would be a typo on my part. no idea how i typed that : (Would you kindly explain this, "you can just record the recored"?? huh
what i meant by all that is with the recorder mounted on the camera shoe you can either capture and sync from the recorder in post OR run the line out of the recorder into the camera live (with the cable folks have mentioned)
- Join Date
- May 2012
- Posts
- 86
06-06-2012 04:51 AM
Many thanks you guys, you have been really helpful
- Join Date
- May 2012
- Posts
- 86
Senior Member
- Join Date
- Jul 2007
- Location
- Toronto
- Posts
- 2,773
06-06-2012 08:13 AM
Cameras : Panasonic GH3 with Grip, Panasonic GH2, Panasonic HMC-150
OIS Zoom : Lumix 12-35mm f/2.8, Lumix 35-100mm f/2.8
06-27-2012 04:31 PM
OK, this is very helpful. I record among other things church events where people are up front and I am 100 feet back in a gallery. I figure Tascam with a feed from a sound board to an SD is the way to go under this scenario but what is troublesome is that even if you synch the camera and the recorder and let them free run, there are reports of the Tascam drifting when recordings go longer than 10 mins. (see http://www.pauljoy.com/gear/camera-a...om-h4n-review/). I assume products like PluralEyes are intended to help re-align.
Next, if am closer, and can run a cable, I presume the best option is no Tascam and just run a cable from the sound board to the camera. Here, i would record one audio channel to an on-camera Rode VideoMic with the other coming from the sound board and i would take the best audio channel. I would expect to skip a lot of the crowd noise by not using the Rode audio track so it ends up just being a backup in case the direct feed is bad.
I lost an entire concert one time by relying on a direct feed but this was before I bought a camera that lets me monitor the in-sound via a headset.Last edited by kwkeirstead; 06-27-2012 at 04:37 PM.
Senior Member
- Join Date
- Jul 2007
- Location
- Toronto
- Posts
- 2,773
06-27-2012 06:09 PM
The synch with pretty much all non-pro audio gear will drift, which is fine as long as the drift is consistent, and most of the current low cost digital gear produces a consistent drift. The trick is to know how to correct for drift, which is actually very easy to do with the right software. I use the "Time Warp" function that is built-in to the low-cost GoldWave audio editing software. GoldWave Audio Editor : $19 US with One Year of Updates
The "Time Warp" function allows you to adjust the length of an audio track down to 0.0001 seconds, so if you know how to calculate how much you need to stretch or shrink your audio, you can synch hours of audio in less than one minute. The trick is to synch your audio track at the beginning of your video, then shift your audio track to synch it to the end of your video, then calculate how much your audio needs to change. So if I was shooting video at 24 fps ( 23.976 IVTC Film ) and my 2 hour audio track is out by 17 frames, then I would divide 17 by 23.976 to get 0.7090 seconds of change I would need to modify my audio track by to get it to match my video track. ( you would know if it was 17 frames long or 17 frames short, in terms of whether you add or subtract the 0.7090 seconds to your audio track to get it to match your video track ) This may sound slightly complicated, but it's SO EASY to do once you have done it a few times.
Myself, I would connect a digital recorder directly to the sound board and let it run wild. I can always adjust the audio timing afterwards to match my video. This is also why I like to let my camera run continuously, so I have one long audio track and one long video track to match just once, and then I can go to town with my video editing because everything is in perfect synch at this point. Yes, you end up with a lot of waste footage, but I would rather have too much than risk missing a shot because the camera was paused.Cameras : Panasonic GH3 with Grip, Panasonic GH2, Panasonic HMC-150
- Join Date
- May 2012
- Posts
- 86
06-28-2012 05:49 AM
Dingo do you think the Lumix 45-200mm lens is a good choice? in other thread people told me it's better the 14-140mm. Don't know what to think
Senior Member
- Join Date
- Jul 2007
- Location
- Toronto
- Posts
- 2,773
06-28-2012 06:18 AM
I originally bought my GH2 with the 14-140mm lens, and ended up selling the lens one month later. I did not like the zoom action on the 14-140, it wasn't smooth enough for me, so I switched to the 14-45mm ( optically better than the 14-42mm ) and 45-200mm lens. I guess a lot will depend on what you like to shoot, how you like to shoot, and what you can afford. The two low cost zooms work well, but they are still very slow lenses. ( I use the 14-45mm in bright light when I want shoot hand-held with an image-stabilized lens. I don't use the 45-200 very often. )
I hope to switch to the 12-35mm f/2.8 and 35-100mm f/2.8 in the future. ( these will be expensive ) I like constant aperture zooms ( no exposure shifts when you zoom ), and the image-stabilization should help with hand-held work. These lenses should have been out when the GH2 first came out, and will make a big difference with what you can shoot in low-light and hand-held. They are also weather sealed, which will be one reason to upgrade to the GH3 when it comes out this Fall. ( it has to be weather proofed )Cameras : Panasonic GH3 with Grip, Panasonic GH2, Panasonic HMC-150
