Page 3 of 19 FirstFirst 123456713 ... LastLast
Results 21 to 30 of 185
  1. Collapse Details
    #21
    Senior Member
    Join Date
    Mar 2010
    Posts
    2,524
    Default
    GH2 Flow Motion v2.02 Update
    • 4GB File-Spanning in HBR 25p, 24H, & 720p with 95MB/sec Class 10 SD cards
    • Improved reliability in SH 720p60 video mode
    With this update, Flow Motion v2.02 has been tested and verified to span reliably across multiple 4GB MTS files, providing extended and uninterrupted recording time on large SD cards. As with previous versions of Flow Motion v2, file-spanning is supported on all Class 10 SD cards in the 60Mbps 24L, FH, and H video modes in both NTSC and PAL frame rates. In addition, 95MB/sec SD cards will span reliably in 100Mbps 24H and SH video modes, and will also span in PAL HBR and FSH modes. (In other words, the only modes not supported for 95MB/sec SD card spanning are NTSC HBR and FSH modes. These modes will record reliably up to the 4GB file size limit.)
    Flow Motion v2.02 also features improved reliability when shooting extremely high-detail scenes in NTSC 720p60 SH mode. The stability adjustments made to 720p60 mode do not impair its 100Mbps performance and have no effect on any of the other video modes.
    To download the Flow Motion v2.02 Update, click on the following link:
    http://www.dvxuser.com/V6/showthread...post1986152355
  2. Collapse Details
    #22
    Senior Member
    Join Date
    Dec 2010
    Posts
    291
    Default
    Awesome! Can't wait to update from 2.01
    0 out of 1 members found this post helpful.
  3. Collapse Details
    #23
    Senior Member
    Join Date
    Mar 2010
    Posts
    2,524
    Default
    Flow Motion v2.02 Low Light Comparison
    Flow Motion v2 maintains its finest quantization quality even in dim lighting situations. These frame grabs taken from a smooth panning shot compare FM2's performance in 1080p 24H, 1080p25 HBR, and 1080p30 MJPEG HD modes. These videos were shot two-stops underexposed, illuminated by a pair of 75W incandescent bulbs. The video gain of each frame was boosted by 50% in Adobe After Effects CS5.5, and the frame grabs were cropped at 200% resolution.
    Flow Motion v2 1080p 24H mode, 200% crop:
    Flow Motion v2 1080p25 HBR mode, 200% crop:
    Flow Motion v2 1080p30 MJPEG HD mode, 200% crop:
  4. Collapse Details
    #24
    Senior Member Ryan Farnes's Avatar
    Join Date
    Oct 2009
    Location
    Washington, DC
    Posts
    646
    Default
    I'm pretty sure I had this patch on my GH2. Flipped to Manual mode to shoot SH at 60p. Camera kept stopping due to "limitation of the card" and froze. Had to remove battery...twice, once with a slower card and a second time with my faster Sandisk that never has problems with high bitrate Driftwood...
    I assume this is not normal?
  5. Collapse Details
    #25
    Senior Member
    Join Date
    Mar 2010
    Posts
    2,524
    Default
    The GH2's 720p60 SH mode is less reliable than the other video modes, and with bright, high-detail subjects, it's possible for the camera to stop recording on rare occasions. If you need absolute reliability in 720p60 mode, I recommend using Flow Motion v2's 720p "H" mode, which has been tested to produce high quality video with a peak bitrate of 60Mbps. In all other respects, 720p H mode works exactly like SH mode, and is also tested to span reliably for extended recording times on 30MB/sec Class 10 SD cards.
  6. Collapse Details
    #26
    Join Date
    Oct 2009
    Location
    Washington, DC
    Posts
    646
    Default
    Cool, thanks for the reply.
  7. Collapse Details
    #27
    Senior Member
    Join Date
    May 2009
    Location
    El Cerrito CA
    Posts
    918
    Default
    Still amazed at how far you can push the color when the video is a bit underexposed with Flowmotion patch.
    HD Video: G7s, ax100s
    Microphones: Sennheiser MKH 80 MKH20 MKH40
    Neumann 11-pattern dual capsule main pair by Rens Heijnis
    Schoeps MK2, MK2H, MK21, MK41
    own design ribbon mics
  8. Collapse Details
    #28
    Senior Member
    Join Date
    Mar 2010
    Posts
    2,524
    Default
    Thanks for the props, DrDave, would you have any grading samples you could upload?
  9. Collapse Details
    #29
    Senior Member Bern Caughey's Avatar
    Join Date
    Jun 2007
    Location
    Los Angeles
    Posts
    4,243
    Default
    lpowell,
    Many thanks for your ongoing work!
    Our editors have been blown away by the quality of the Flow Motioned footage.
    Best,
    Bern
    1 out of 1 members found this post helpful.
  10. Collapse Details
    #30
    Senior Member
    Join Date
    Mar 2010
    Posts
    2,524
    Default
    I recently acquired a Panasonic Lumix 45-175mm f4-5.6 X lens with auto-focus, OIS and motorized zoom features. This lens' auto-exposure features prompted me to put additional testing time into the GH2's more consumer-friendly modes and features. A number of Flow Motion v2 users have reported reliability issues when shooting 100Mbps 720p SH video in auto-exposure modes (i.e. P, A, S, or iA exposure modes, rather than the Creative Movie M exposure mode.) In addition, the GH2 offers a number of enhanced exposure features: auto-ISO, i-Dynamic, and i-Resolution settings which can be enabled in any video mode.
    There's one hazard to using Lumix auto-focus lenses along with the GH2's auto-exposure features - in 720p SH video mode, recordings may fail sporatically and the camera may need to be restarted. To avoid this pitfall in auto-exposure modes, I recommend using Flow Motion's 60Mbps 1080i FH and 720p H video modes when using any combination of the following features:
    * P, A, or S exposure modes or when shooting in iA mode.
    * Auto-ISO mode.
    * iDynamic auto-contrast mode.
    * i.Resolution mode.
    * Motorized zoom lens operation.
    I've tested and confirmed these features to work reliably at 60Mbps in 1080i FH and 720p H video modes. In addition, all of the Gh2's automated features will work reliably at 100Mbps in 1080p 24H and HBR video modes, as well as in 80% Slow-Motion 24H modes. The 60Mbps FH and H video modes also support 4GB file-spanning on 30Mbps Class 10 SD cards, and produce excellent motion picture quality that is just a notch more compressed than Flow Motion's 100Mbps FSH and SH video modes.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
