Results 1 to 7 of 7
  1. Collapse Details
    getting sharp focus.
    #1
    Default
    Hi all,
    I bought a used dvx100b a while back and have been shooting some test footage following Andy Starbuck's tips. Anyhow the wide angle shots im getting look soft/out of focus, i've been doing thread searches here regarding focus but im still not sure if my camera is focusing properly when at the wide angle, as it looks soft to me. Heres some footage i shot a couple of days ago, all using auto focus, auto iris, scene file 1 factory settings. Is the focus correct? Is it a back focus problem? Any advise would be appreciated thanks.
    https://vimeo.com/42847641 f.4.0 i think. detail level 0
    https://vimeo.com/42849221 f.48, detail level +2 i think
    https://vimeo.com/42886966 f 6.8 detail level 0
  2. Collapse Details
    #2
    Default
    The reason it's soft is because you are using auto focus. Never use auto focus, always use manual focus and I will guarantee you will get sharper video.
  3. Collapse Details
    #3
    Senior Member
    Join Date
    Mar 2004
    Location
    LA,California
    Posts
    537
    Default
    Search this forum for the proper way (distance,F stop, etc.) to test for a back focus problem. Such problems can often be resolved with a "software alignment" at an authorized repair facility..
    Ken
  4. Collapse Details
    #4
    Default
    To get the camera serviced costs $$$. Bet it would cost nearly more then the cameras worth. I thought the auto focus on the dvx was accurate, like if your shooting documentary style with spontaneous camera moves it would be difficult with out the auto focus. I'll have to shoot some new footage trying the zoom in focus and zoom out method / test the back focus. If the back focus is out i'll have to improvise some how like find the widest angle the camera will focus correctly on and shoot no wider then that. In general is the lcd reliable for judging focus? I guess it depends, in my case i would not have a focus puller, i could use a bigger monitor though. Thanks
  5. Collapse Details
    #5
    Junior Member
    Join Date
    May 2005
    Location
    Illinois
    Posts
    29
    Default
    A couple of those clips don't look overly soft to me for SD footage. You won't be able to get HD sharpness from a SD cam, although if you manually accurately focus you can improve it some for Vimeo/YouTube by uprezzing the footage. How does the video look straight from the cam on a TV?
  6. Collapse Details
    I appreciated
    #6
    Default
    thanks, you right have nice day
  7. Collapse Details
    #7
    Default
    Yes i'd kinda forgot how low rez dv is, i watched the 'the puffy chair' again which was shot on a dvx100 and it put things in perspective, also checked out '28 days later' and man is that soft. Had my camera checked on a focus chart and the focus is correct. Happy days.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
