I have a 10 minute project I am trying to export. Canon 5d footage and when I export h.264 file the audio goes silent at 3:00. Can someone please help? I've exported several times and it consistently happens at 3 mins! Thanks!
Results 1 to 10 of 17
Junior Member
- Join Date
- May 2012
- Posts
- 7
05-14-2012 06:13 PM
Junior Member
- Join Date
- May 2012
- Posts
- 7
05-14-2012 08:37 PM
In the timeline all sound is there but when it exports it is gone. Please anyone what can I look for? I can not figure it out.
Junior Member
- Join Date
- May 2012
- Posts
- 7
05-15-2012 12:55 AM
Anybody? This is an important project!
Thank you!
Senior Member
- Join Date
- Dec 2010
- Location
- San Diego
- Posts
- 555
05-15-2012 12:59 AM
Did you grade in Resolve? I've found that there's some sort of glitch with the XML that Resolve generates that causes this problem.
I shoot everything on 8mm tape. BALLER STATUS
Junior Member
- Join Date
- May 2012
- Posts
- 7
05-15-2012 01:25 PM
No I just color graded with apple color.
- Join Date
- Apr 2006
- Posts
- 81
05-15-2012 03:02 PM
You made sure there isn't a Stems-problem? Which roles you set to export?
Also happens when you try to just export the audio separately?
Junior Member
- Join Date
- May 2012
- Posts
- 7
05-15-2012 08:48 PM
I do not know what a stems problem is. I just recently switched to FCP X so I am still learning the system. I will try to just export audio now.
Junior Member
- Join Date
- May 2012
- Posts
- 7
05-15-2012 08:52 PM
When I just export audio it does the same thing.
Bronze Member
- Join Date
- Jan 2005
- Location
- Baton Rouge/New Orleans, LA
- Posts
- 3,920
05-16-2012 09:11 AM
Exactly how are you exporting? Command-E, then set it to Current Settings, Video And Audio?
Junior Member
- Join Date
- May 2012
- Posts
- 7
05-16-2012 12:04 PM
I am going to share then export h.264 audio and video. If I start a new project and export a 5 min clip of something else I don't lose audio but on the current 10min project I am working on audio cuts out at 2.31 even if I move events around.
Final Cut Pro X audio export problem???
