I'm using my nex5n with the LA-EA2. I love the combo. However as a video shooter, I am concerned with the shutter speed jumping around when the LA-EA2 is connected. Hopefully I am missing something. Is there any way to set the shutter speed to a constant setting?
Thanks!
Thread: NEX5N LA_EA2 Help!
Results 1 to 3 of 3
Senior Member
- Join Date
- Apr 2010
- Posts
- 207
04-28-2012 06:35 PM
04-28-2012 08:00 PM
Well; for the La-EA2 use the AF continuous must be in P (program) mode, that limit the aperture max at f3.5, but is you don´t need AF continuous the best mode you can use, is you´re serious at recording is in M (Manual) mode, here you set your aperture and shutter speed at a fixed value, shutter speed must be in 50 for Pal countries and at 60 for NTSC.
Also you can use S (Shutter) mode to set a constant speed and leave the exposure control to the camera trough aperture changes.www.cajitacreativa.com
Sony Nex FS100 | Sony Alpha 77 | Sony Nex 5n
MacPro 8-Core | Led Cinema 24" | 4TB | 32GB
Cinema 4D R13 | Creative suite CS6 | ZBrush4r3
Senior Member
- Join Date
- Apr 2010
- Posts
- 207
04-28-2012 08:11 PM
Those tips helped! Thank you. My last issue is when I shoot video with the LA-EA2 adapter on, it sets my aperture at 3.5 which is fine. I am just lost as to why is sets my shutter speed at 1/60th and I am not able to change it at all and or set it at the speed I want.
NEX5N LA_EA2 Help!
