Results 1 to 7 of 7
  1. Collapse Details
    HyperDeck Shuttle 2 SDI CABLE
    #1
    Junior Member BVK_FILMS_INC's Avatar
    Join Date
    Jan 2012
    Location
    Vancouver, BC
    Posts
    18
    Default
    Hey,
    Can someone give me the link the proper SDI cable for the HyperDesk Shuttle 2?
    First I ordered this one thinking it would work: http://www.bhphotovideo.com/c/produc...LE_to_DIN.html
    Then I got this one http://www.bhphotovideo.com/c/produc...LE_to_DIN.html
    It won't fit into the connection on the AF100 does it require an adapter?
    I also ordered two of them so I could hook up my DP6. Can someone please help me out?
    Video Producer - IATSE 891 Member Lamp Op
    Gear: Panasonic AF-100, Canon 5D III (ON ORDER), HyperDeck Shuttle 2, RedRock Live Lens, ARRI Lighting Kit, SmallHD DP6-SDI, Cartoni Sticks, Canon EF 50mm 1.4, Canon EF 85mm 1.8, Canon EF 16-35mm 2.8
    http://www.bvkfilmsinc.com
  2. Collapse Details
    #2
    Senior Member
    Join Date
    Oct 2010
    Location
    Toronto, Canada
    Posts
    476
    Default
    Hmmm. Surprised the second one didn't work - since that's the one B&H bundles with the Shuttle.
    How, exactly, is it "not fitting into the connection"? What is the physical issue? ('cause these are definitely SDI cables, and the AF100 definitely has an SDI connector).
    I believe others have been using this cable successfully:
    http://www.markertek.com/Interface-S...ml?RD1-DINAB-1
    I.N.A.T.E. - I.A.T.S.
  3. Collapse Details
    #3
    Senior Member Igelkott Film's Avatar
    Join Date
    Dec 2010
    Location
    Sweden
    Posts
    374
    Default
    You have bought a male BNC and the one in your camera is male.
    You have to buy a female to female adapter for this to work
    Igelkott Film is Hedgehog Film
    www.igelkottfilm.com
  4. Collapse Details
    #4
    Senior Member
    Join Date
    Jul 2006
    Location
    Minneapolis
    Posts
    1,303
    Default
    You can use adapters to make those work otherwise like Steve R said Markertek carries cables that work without adapters.
  5. Collapse Details
    #5
    Join Date
    Jan 2012
    Location
    Vancouver, BC
    Posts
    18
    Default
    Thanks guys..
    Is this the right one? http://www.bhphotovideo.com/c/produc...le_BNC_to.html
  6. Collapse Details
    #6
    Senior Member
    Join Date
    Jul 2006
    Location
    Minneapolis
    Posts
    1,303
    Default
    Quote Originally Posted by BVK_FILMS_INC View Post
    Thanks guys..
    Nope you need male to male.
    this one: http://www.bhphotovideo.com/c/produc...le_BNC_to.html
  7. Collapse Details
    #7
    Join Date
    Jan 2012
    Location
    Vancouver, BC
    Posts
    18
    Default
    Quote Originally Posted by brian@202020 View Post
    nope you need male to male.
    This one: http://www.bhphotovideo.com/c/produc...le_bnc_to.html
    thanks very much
Posting Permissions
  • You may not post replies
  • You may not edit your posts
