Does anyone have any inkling how to create an effect to blag that the camera is in water?
I have a scene where someone looks into the toilet and I have a shot from inside the toilet bowl. Now I just need to make it look like it is underwater?
Any ideas folks?
Thread: Camera in water effect?
Results 1 to 7 of 7
- Join Date
- Apr 2011
- Posts
- 80
03-19-2012 12:41 PM
03-19-2012 02:20 PM
Put a GoPro underwater.
03-19-2012 04:58 PM
Yeah, that. Or shoot upwards through a glass bottomed tank (fish tank?) positioned on a table or frame, taking care to avoid reflections. GoPro option would probably be quicker, easier and cheaper.
03-20-2012 05:58 PM
As stated, using a Go Pro would probably the most realistic solution, however, you could always create a CG water element to get just what your looking for. All you would have to do is make sure the water's refraction level is just at the right intensity and that the element sits welll enough in your scene. In reality you might be able to get away with duplicating your footag and adding some displacement, transparency and a slight tint in AE.
-BLast edited by bgodoy; 03-21-2012 at 04:58 AM.
03-21-2012 09:33 AM
Never tried it, but put some water in a resealable plastic bag and lay it on the lens. Postion the camera beside the toilet.
Senior Member
- Join Date
- May 2008
- Posts
- 209
03-21-2012 04:27 PM
use a glass cookware 9x13 dish (or whatever) - mount the camera up, and support the dish properly so it cannot leak ontot he camera - slight ripples with fingers is all you need
Senior Member
- Join Date
- May 2008
- Posts
- 209
03-21-2012 04:29 PM
there's also the classic (cliche) mirror at the bottom of a pan with water bouncing a watery reflection onto the actors - you could probably film on an angle that way too, down into a mirror with water on top of it, 45 degrees or some such
