When connecting my FS100 to my 37'' LED Panasonic am i viewing a 4:2:2 image?
The reason I ask is because I was shooting and monitoring some test footage today on my Panasonic. Once i brought the footage into premiere I could notice a difference between what I was monitoring and what was recorded.
And to clarify I also viewed the footage on the same monitor when editing it.
Thank you,
Aaron
Thread: 4:2:2 while monitoring?
Results 1 to 10 of 10
Senior Member
- Join Date
- Nov 2008
- Posts
- 128
03-12-2012 02:49 PM
Senior Member
- Join Date
- Jul 2005
- Location
- Florida
- Posts
- 299
03-12-2012 08:47 PM
.....and that difference was???? ;-)
FCP 7.0, PP 6, MacPro Octo 2.8, MBPro, EX1, FS100, MXO2, Sachtler FSB6
Senior Member
- Join Date
- Nov 2008
- Posts
- 128
03-12-2012 11:29 PM
Sharpness and the color rendition seemed better. I guess I answered my own question, but I was curious if someone with the technical knowledge knew the answer.
03-13-2012 12:51 AM
Are you editing at half resolution, in other words, does the image get sharper when you pause it?
03-13-2012 06:54 AM
Yes, the FS100 outputs 4:2:2 and records AVCHD at 4:2:0.
However the difference isn't necessarily very noticeable, as the FS100's AVCHD is very good. See:
http://crookedpathfilms.com/blog/201...s-ninja-tests/
Note that in this test:
http://prepostconsulting.com/en/engl...mparison-test/
the tester found AVCHD to be less sharp, but subsequently found that the poor quality from the AVCHD was due to an ingestion problem causing interlacing artifacts. So I wonder if maybe you're seeing a similar issue?
Senior Member
- Join Date
- Nov 2008
- Posts
- 128
03-13-2012 01:27 PM
Thanks for the responses everyone. I should clarify that the image I got off my cards (AVCHD) looks superb! But the monitored 4:2:2 image looked much cleaner. I have CS5 so everything plays nicely together so it wasn't a codec or resolution issue .
However the reason I asked this question in the first place was because I've read that only certain recorders can record the 4:2:2 image, such as the Ninja by pulldown method. I was simply wondering if the communication between my camera and monitor automatiaclly do this to achieve a 4:2:2 image.
Thank again,
Aaron
03-14-2012 06:59 AM
There's no "pulldown" for 4:2:2. 4:2:2 just means there's more colour detail. Your monitor ought to display it no problem.
Are you using the same monitor in Premiere? If you are, and it looks worse than the live signal, then I really would suspect that there's a settings mismatch... like recording progressive but editing interlaced, or something.
Do check out the second link I posted above. That guy was using Premiere too, and he still got messed up somehow.
Senior Member
- Join Date
- Nov 2008
- Posts
- 128
03-14-2012 12:10 PM
Hmmm according to this forum http://www.dvxuser.com/V6/archive/in.../t-245172.html devices such as the ninja can't record a direct 24P hdmi out signal. They record it as a 60i then you have to tell your editing system to pull out frames to get back to 24P
03-15-2012 11:09 AM
Thats true, but 4:2:2 has nothing to do with frame rate. 4:2:2 is the Chroma Subsampling Ratio.
Also are you viewing the shots in Premier on your Panasonic LED? If your viewing it on a computer monitor, then thats also another reason the footage looks different. TVs such as LEDs display colorspace in r.709 and your monitor is probably something near sRGB, so your going to get a different looking image on different displays.
Senior Member
- Join Date
- Nov 2008
- Posts
- 128
03-15-2012 12:16 PM
Yes I'm viewing the footage thru premiere on my Panasonic. I also have an older 28in hannsG LCD monitor which is terribly inaccurate with color and contrast reproduction. I bought an led tv to have a more accurate representation of what my final output would be.
I should stress again that the footage looks awesome both from the avchd encode and the live feed. My original question should have been does the tv automatically apply pull down via hdmi so that I'm viewing a 4:2:2 24P Image.
